Modding How to build a touchscreen all-in-one PC
Discussion in 'Article Discussion' started by Lizard, 9 Jul 2010.
  1. Sea Shadow
    Sea Shadow aka "Panda"
    15 Jan 2004
    I'm pretty sure that the cameras in Microsoft Surface solutions don't use cameras that see the heat from your finger, just IR light around the 800-950nm range. After all, the systems are heavily pitched with their object recognition based on the IR tags that are affixed to devices, and the tags (stickers) don't put out heat but are easily capable of reflecting IR light from below. I believe it is a DI (diffused illumination setup) with the 5 cameras, where there is an IR source in the enclosure, and the cameras have color filters to only allow IR light. Actually it is not all that difficult to build a similar system. Nearly 3 years ago I had a simple multi-touch system running at home that was quite similar to the technology behind Surface, but I only used 1 camera instead of 5.
  2. Bakes
    Bakes New Member
    4 Jun 2010
    Yes, using FLIR cameras would be far too expensive - you're talking $3-4k per camera at least, with a low resolution.
    Microsoft might have made some bad decisions in the past, but they aren't that dumb.
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    pretty sweet mod, I think they make itx sized boxes that mount on the back of monitor Versa (?) holes
  4. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    i want go go gadget arms!!!!!!!
  5. mrbens
    mrbens New Member
    15 Aug 2009
    It's not really a 'touch-screen' if you don't actually have to touch the screen!
    Joking aside this sounds great, and I hate fingerprints on things so just moving your finger close enough for the sensor but not touching the screen sounds better to me. :)
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    when reading webpages that are bigger than your screen, touch is useful.
    try a touchscreen in bad company 2 on the kit selection screen, its so easy, lol.
    does anyone read gizmo online mag, turning pages makes it feel like a real magazine, well almost anyway, lol
  7. [- pio -]
    [- pio -] New Member
    2 Feb 2004
    Yeah, he tried using one in this project, but the stand on the monitor was already using the VESA mount holes..
  8. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    You can get the touch screen kits for netbooks on ebay pretty cheap.
    Installed one on my Aspire One, fair pain to install it but it is rather useful
  9. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    are one for SFF any good???
  10. wuyanxu
    wuyanxu still wants Homeworld 3
    15 Aug 2007
    no mod log? :(
    cheers for this idea, will look into it
  11. Howling_Wolven
    Howling_Wolven New Member
    2 Oct 2012
    They exist.
    I've had one =P.
    Was so much fun, but the glass cracked, breaking the touch system =/
    Dell 2120 with 10.1" hires touch monitor, 320GB SSD(Spinning storage drive), N550 dual core, and 3G card. Those were fun times. :hip:
Tags: Add Tags
