Modding How to cheat a bit - Cable braiding
Discussion in 'Modding' started by Big Elf, 27 Apr 2010.
  1. Big Elf
    23 Apr 2009
    M7ck likes this.
  2. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    I had seen these on a couple of sites. looks good and a lot easier that doing it your self.
  3. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Cant really go wrong for £4
  4. stonedsurd
    11 Mar 2009
    But they don't look as good as *really good* sleeving.
    And sleeving is fun :p
    mvagusta likes this.
  5. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Available in all shades of Black !
    OK, if you don't fancy DIY.
    I prefer to have a colour choice and do my own.
  6. capnPedro
    11 Apr 2007
    And it's an extra 25cm of cable you have to hide.
  7. Unicorn
    25 Jul 2006
    This is a neat idea and all, and it's great if you're doing a quick cable tidy or mod, but there is no substitute for putting a lot of time into sleeving your PSU just the way you want or need it, and doing it meticulously so that it looks like a completely professional job.
  8. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    That extension defeats the purpose of braiding, as it just adds clutter, instead of hiding it.
    +1 and a bit more resistance to boot.
    Everyone should buy every cheap pc part they see, and install them asap.
    October and capnPedro like this.
  9. Hazchem
    Hazchem Minimodder
    3 Dec 2004
    Oh look KustomPcs have raised the price, how predictable.
  10. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    For a second I thought I'd see literally braided cables.
  11. sejutaluka
    sejutaluka What's a Dremel?
    23 Nov 2007
    it's a nice stuff, unfortunatelly it's out of stock. maybe you can find at other stores.
  12. bruce_rob
    18 Apr 2010
  13. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Scan sells them as well now, in stock!
  14. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    These things are great. Not everyone can sleeve like a pro...and these dont void warrenties. Its just a shame they dont offer different colours...yet.
    I think these are a NZXT showing they watch modding styles, communites and trends. Good for them.
  15. bruce_rob
    18 Apr 2010
    just received mine and it looks really smart would def say buy one if you want the braid effect.
  16. mvagusta
    24 Dec 2006
    It's an extension. It's what you use, when you need to extend your mobo power cable :duh:
    The only way it could be used to improove the appearance of cabling, is if the standard part of the psu mobo power cable was concealed - all the other cables would have to be modded to suit of course.
  17. skreenname
    skreenname SFF Forever
    11 Jun 2009
  18. Tasslehoff
    Tasslehoff What's a Dremel?
    25 Jan 2010
  19. bruce_rob
    18 Apr 2010
    i have received and installed mine and i must say i am impressed with the results, will post a pic up tomorrow
  20. Unicorn
    25 Jul 2006
    Believe it or not I'm going to order one of these for one of my servers. Not for asethetics, but to use as an extension. the 24 pin connector on my old 600W Seasonic PSU is *just* long enough to make it to the socket on the motherboard after passing through my cable management (read: cable hiding) holes but I want a little extra so there's no strain on the motherboard.
