Build Advice How to connect a male fan connector
Discussion in 'Hardware' started by Bladesingerz, 5 Mar 2012.
  1. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    I just recived a couple of male and female fan connectors, I already installed the female connectors but I have nomidea how to connect the male ones :blush:
    Do I just solder the wires onto the pins or is there an easy way?
    Here is a picture of the connector
  2. Deders
    Deders Modder
    14 Nov 2010
    Is that for 2 female connectors to plug into? If not then just solder them on I guess, Or you can get something from hardware shops (not sure what it's called) that is metal and wraps around wires and pins.
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Looks more suited to a PCB mount to be truthful.
    What's wrong with a standard female 3-Pin header?
  4. Bladesingerz
    30 Nov 2011
    I bought these together with the female connectors but didn't notice untill a few days ago that they weren't like the normale male connectors..
    I'm quite confused how to make these work...
  5. Teelzebub
    27 Nov 2009
    Yea they solder on
    Bladesingerz likes this.
  6. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    the males can go around in a circle, like a train around the room
