Cooling How to create this effect
Discussion in 'Hardware' started by Aman, 22 Oct 2006.
  1. Aman
    Aman What's a Dremel?
    22 Oct 2006
    Anybody know a good coolant that produces that kind of effect? I need the exact effect. so list all the parts like uv light uv coolant and the dye and stuff.
  2. Krikkit
    21 Jan 2003
    Uhm... UV Light, UV-Blue coolant, clear tubing, careful mixing.
  3. Aman
    22 Oct 2006
    I have clear tubing any idea what kind of light and coolant?
    and any ideas on mixing?
    i would really appreaciate if someone figures this out.
  4. stevie1556
    stevie1556 What's a Dremel?
    29 Jul 2006
    Best way of doing this would be to get a uv light, get the blue uv dye, put the water in a bowl, put the dye in little by little until you get that effect. I think that's the best advice your going to get.
  5. Aman
    22 Oct 2006
    but i need to know the dye and the coolant
  6. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    looks like blue PC Ice.
  7. led_zeppelinzoso
    led_zeppelinzoso What's a Dremel?
    13 Jul 2006
    uhh... I think its UV reactant tubing, or most likely a candy apple blue UV paint
  8. KayinBlack
    2 Jul 2004
    OK, that's some custom stuff, I think.
    Those are UV blue reactive NON-LIGHTED fans, a UV blue reactive acrylic block top, and that may/may not be UV reactive tubing and NOT the water. Had to look at it closer.
    If you'll look, the entire top glows evenly, as do the fans. You can see that by the evenness it's reacting, not producing the light. If it were producing parts would be brighter.
    Also, the tubing would have less of a fuzzy edge if it were a UV reactive coolant, as it would be bounded by the clear tubing, and its edge would be sharper due to the filtering effect of the clear tubing walls.
    I've taken lots of shots of WC cases before, and I've owned a LOT of UV blue stuff, so I have seen a lot of this.
    Coolant may still be PC Ice though, it's getting real popular...
    Strike that, it's definetely UV tubing. You can see the edges light up more than the middle, cause you see more profile on the edges.
  9. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    Yeah it looks just like the UV tubing in my rig which glows blue, looks uncannily like it.
    Jimbo
  10. D3DAiM
    D3DAiM Slightly Stupid.
    3 Oct 2006
    Maybe PC ICE dude.
