Modding how to create white smoke?
Discussion in 'Modding' started by Lineage, 17 Jan 2006.
  1. Lineage
    Lineage What's a Dremel?
    19 Sep 2003
    i want to test my custom case's air flow, anyone know how to create white smoke or other colour smoke?
    thx
  2. DR_D
    DR_D What's a Dremel?
    8 Nov 2005
    use a smoke pellet
  3. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    uhh keep on poking your psu with galvanized steel...
    I believe those cheapy little smoke bombs that are in fireworks packs work nice. Dry ice evaporates too fast.
  4. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    Use a smoke match/pellet/bomb
    You can buy them from heating spares merchants (used to check flue integrity)
  5. pccompuman
    pccompuman What's a Dremel?
    28 Aug 2005
    im not possitive but i thinkk that you get white smoke when you burn burlap (sp?) i heard somewhere that that is what bee keepers use for there little smoke things.
  6. Draknog
    Draknog What's a Dremel?
    9 Feb 2004
    An easy way to make your own smoke:
    4 parts sugar
    6 parts potassium nitrate (Salt Peter)
    Heat this mixture over a LOW flame until it melts, stirring well.
    Pour it into a future container and, before it solidifies, imbed a
    few matches into the mixture to use as fuses.
    :eeek: PLEASE NOTE: :eeek: A small amount of this stuff makes ALOT of thick white smoke. Try about a teaspoon outside to see how potent it is.
    Enjoy! :naughty:
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
  8. HapeMask
    HapeMask What's a Dremel?
    19 Jan 2006
    My younger brother made some of this stuff awhile back and it certainly did make a ton of smoke, enough so that a small tin lasted a few months. However I kinda remember it leaving a residue, not sure if the smoke will really do much in terms of gumming things up, but it might be something to consider before running it through your box (assuming it has all the parts in it, not just fans.)
  9. qbert3
    qbert3 What's a Dremel?
    7 Dec 2005
    heh i dont know about you but... what about burning incense? sounds pretty simple... easy to clean.
  10. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    and at least it smells decent until it dissapears.
    on that subject, ciggarettes if you already smoke and don't care about the smell.
  11. JCG
    JCG What's a Dremel?
    1 Dec 2005
    Or go to a shop sell miniature train and such, most off them will have have smoke liquids for in the trains.
    Just put it is a metal spoon or something like that, and heat it up (soldering iron/lighter will do the trick).
  12. furqan
    furqan What's a Dremel?
    2 May 2004
  13. The_Dude2040
    The_Dude2040 What's a Dremel?
    25 Nov 2005
    thats what i was thinking
  14. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Are you guys sure that none of this smoke will harm his components? I mean, his computer has to be on for him to test out the fans. I personlly would NOT use cigarette smoke, its not thick enough and it just smells damn nasty, not to mention all the tar thats in it.
  15. lizard.boy
    lizard.boy What's a Dremel?
    14 Jan 2004
    White smoke coming from the vatican means that a new pope has been elected.
    howabout setting an entire matchbook on fire and then blowing it out. tons of smoke and that pleasent smell of sulfer. :p
  16. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Or you could use a talcum powder dust (what I use when designing nonstandard cases/case cooling) because it's nonvolatile and can be brushed off anything it sticks to...
  17. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    how bout a boat flare, the smoke kind. They throw off a huge amount of smoke.
    added bonus is you can get coloured ones.
  18. HapeMask
    19 Jan 2006
    :eeek: Wow that might be a bit excessive no? :D
  19. Lineage
    19 Sep 2003
    cant even see my case if use that...lol, maybe a reduced size version will work ^^
  20. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    Do post vids once you get that white smoke worked out, i've always been interested in seeing just how efficient the average case cooling is.
