Modding how to create white smoke?
Discussion in 'Modding' started by Lineage, 17 Jan 2006.
  1. Lineage
    Lineage New Member
    19 Sep 2003
    i will test it in my custom build case, its not the same shape nor layout as a mid tower case, and i have no idea when i will finish it, so dont hope too much ^^'
  2. Shpoon
    Shpoon New Member
    12 Jan 2006
    Even though dry ice melts really quickly...I'd say it's the best one :/
  3. Faind
    Faind New Member
    30 Jan 2006
    id say light a half dozen or so cone incence and set them by your intake or if there a healthfood store around get a sage "smudge stick" both thoes a re cheep and easy to get ahold of, i mean wading up some printer paper on a dinner plate would work but it wouldn't be clean, there is no such thing as clean smoke. i dont think running a little smoke through a PC is going to hurt it smokers run much more over all and i'v never head of computer dieing because the owner smoked.
  4. Ener
    Ener New Member
    17 Oct 2005
    if you have a lots of cats or dogs thats a different story, my friends cats where shreading hair and he has so much dust and hair on his intake filter
  5. speedfreek
    speedfreek New Member
    9 Nov 2005
    Look at the hs on my parents computer, more hair on it then on the dog.
    I think that a ton of inscence would be the best bet. Im suprised there hasnt been a drug reference yet.
  6. pjotero
    pjotero belgian
    2 Jan 2006
    where can you get the potassium nitrate ( can anyone translate in dutch or give the fomula) I ve only tried one apothecary so he maybe an exeption.
    (or he doesn't want to give it to me, im only 15,5 years old)
  7. obzelite
    obzelite New Member
    9 Jun 2005
  8. pjotero
    pjotero belgian
    2 Jan 2006
  9. Graffix
    Graffix New Member
    5 Jul 2005
    lol that comment made me laugh. No time for Terrorests and more time for fraudsters :rolleyes:
  10. bender386
    bender386 New Member
    5 Jan 2006
  11. pjotero
    pjotero belgian
    2 Jan 2006
    does anybody know where you can get potassium nitrate (kno3)??? or for what it is used?
    preferably in belgium.
  12. JCG
    JCG New Member
    1 Dec 2005
    kunstmest :D (sorry don't know the english word for it).
    But you should the carefull when buying it, or that least don't ask straight for KNOMakes the enclosed text a subscript. Because usually when it isn't for plant it's for smoke bombs, and they can give you a dificult time when you try to buy it (don't ask how i know this :eek: )
  13. Jokkocze
    Jokkocze New Member
    16 Dec 2004
    if you lived in a country where 230w were standard, it wouldnt be any problem.. Then you could just've taken a crappy psu, and switch it to 110w. Then you just start it, and it blows thick, black smoke! Smells pretty bad tho
  14. bender386
    5 Jan 2006
    its normaly used for fertilizer. so go to one of those big gardening places and see if they have any.
  15. Drexial
    Drexial Member
    28 Jul 2005
    yeah i dont know what they use to test areodynamics in wind tunnels, but it can withstand up to 100mph winds and still stay in a streem. but i have no idea what it consists of unfortunetly
  16. pjotero
    pjotero belgian
    2 Jan 2006
    Thanks for the idea of fertilizer
    I 'll try it ( I hope i don't have to buy it in bags of 15 kg :wallbash: )
  17. H311R4153R
    H311R4153R New Member
    28 Mar 2005
    Search for "kalkammonsalpeter" [dutch]Het is kunstmest van ASEF en het zit in een groene verpakking, http://gamekeeper.deds.nl/kas_suiker_rookbom.html kijke hier eens[/dutch]
  18. Lineage
    Lineage New Member
    19 Sep 2003
    oh, i remember when my grandfather did bee farming, he burned dry grass and blew it to drive off the bees, only if i remember more deteils :wallbash:
  19. offroadracer789
    offroadracer789 New Member
    9 Dec 2004
    i got 5 pounds of kno3 off of ebay for $15.00
    You can use it to make gunpowder, but mostly it is used for model rocket engines, smokebombs, and fireworks.
    From what my chemistry teacher told me, nobody really cares if you make smoke bombs since they have little potential to hurt people. Imo, there are much better explosives that can be made than gunpowder.
    I was going to try a smoke bomb on my computer when i reuild it in a couple of weeks to test the airflow. Im still trying to figure out the best mixture for them. I heard that u can use baking soda as a moderator for smoke bombs, but i have yet to try it out.
  20. pjotero
    pjotero belgian
    2 Jan 2006
    maybe it is this you are looking for??
