Build Advice How to determine bottlenecks
Discussion in 'Hardware' started by TheMusician, 29 Jul 2009.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    I was wondering how you guys determine whether something will be/is a bottleneck or not, without testing other CPUs- unless there is no other way.
    My friend wants to build a $454 system:
    CPU: Core2Duo E8400
    RAM: 4GB G-SKILL DDR2-800
    GPU: EVGA GTX260 896MB
    Mobo: Gigabyte GA-G41M-ES2L G41 MicroATX
    PSU: 500W
    I think it's a great deal- what do you think?
    And my actual question: Will the CPU bottleneck the GPU? I would think that it wouldn't, since i've heard that as long as you have a decent dual-core CPU with a decent amount of cache and an FSB of 1066MHz or over, it really doesn't matter, and games will really only be affected by the GPU.
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    That looks like a nicely balanced system actually.
    The only bottleneck here will be the mechanical hard drive, but then most of us can live with that, especially without spending some serious money :)
    Though i'd be interested to know what PSU (brand/model) he is intending to use. This can make all the difference (esp. to system stability), almost as much as supposed wattage.
  3. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Yer, the Hard Drive will be the bottleneck
    Btw... Micro ATX Motherboard
    And also, the CPU will affect your frame rate depending on the game, some games rely heavily on CPU so will be affected by the CPU, some are written to take advantage of quad cores, some are GPU intensive, it just depends on the game
