Windows How to disable Auto Arrange in Windows XP?
Discussion in 'Software' started by itsonlydanny, 26 Feb 2013.
  1. itsonlydanny
    itsonlydanny What's a Dremel?
    23 Feb 2010
    Hi,
    This is driving me nuts! :D. Using Windows XP, I want to disable/kill the Auto Arrange function in My Pictures (and all sub-folders). Unticking it in context menu (right click) makes no difference nor (anymore) does editing the Registry Entry (ie, HKEY_CURRENT_USER/Software/Windows NT/Current Settings/Program Manager/Settings/Auto-Arrange/Edit D Word Value, etc.
    Any idea what I should do next?
    Thanks,
    DANNY O'DARE
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    upgrade from a 10 year old OS?
    But other than that if you go into view -> options -> view and do reset folders that should reset it all, then set it how you like then do apply to all folders and it should be set... maybe... it's been years since i touched XP
