How to disassemble a Dell Ultrasharp 1707 Monitor
Discussion in 'Tech Support' started by timmythemonkey, 11 Jul 2008.
  1. timmythemonkey
    timmythemonkey Monkeymodder
    27 Apr 2006
    Hey guys got a small problem.
    The power button on a Dell Ultrasharp 1707 Monitor has sunk into the bezel meaning it can no longer power on. Its a simple fix once I can get inside it, but thats where I'm stuck.
    Its outside of warranty, so I have nothing to loose.
    Any idea how to get the covers off of this awkward thing? I'm sure one of you guys on the Bit-Tech forums has the know-how!
  2. Krikkit
    21 Jan 2003
    Have a look around the edge of the bezel, where the front and back halves meet there's usually some plastic clips (usually not visible, but marked somehow). You'll need a screwdriver to pry them apart, and they can be a real ******* too.
    I had to disassemble a Philips TFT last week and the clips were made so that they couldn't really be undone without nearly breaking the damn thing to bits... :grr:
  3. timmythemonkey
    27 Apr 2006
    Thanks for that! you were right, although they weren't marked as far as i could see, though a little brute force showed them up nicely.
    Got the bezel most of the way off, but now its time to head home for the weekend, so I'll continue my monitor breaking... I mean repair...:rolleyes: next week.
    Thanks again for the prompt reply! :thumb:
  4. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    If you can slide something thin in the gap like a credit card it'll slide round until it hits a clip. Makes it easy to find the clips.
  5. timmythemonkey
    27 Apr 2006
    I ended up using 2 screwdrivers and a spare PCI slot plate... whatever those useless bits are called, as it was a nice L shape.
    The monitor is now back together again and working fine after having repaired the power button, the plastic had snapped in 2 places, one where it depresses the actual switch itself, and another that holds the power button to the rest of the button assembly. A bit of superglue and a tiny piece of pencil eraser later and it was fixed. Definately worth a little effort to save what is still a good monitor.
    Thanks for all your help guys!
  6. EnglishLion
    2 May 2008
    Nice to hear you were successful. Don't suppose you got any photos for others to reference - clip positions, button weak points etc?
  7. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
  8. saspro
    saspro IT monkey
    23 Apr 2009
    A guitar plec is perfect for sliding around monitors & similar bits of kit to release the clips.
  9. phenoptix
    16 Aug 2006
    Probably would have been easier than the blood donor card I knackered to open mine!
