Other How to disassemble this light!?
Discussion in 'General' started by wyx087, 23 Jan 2021.
  1. wyx087
    15 Aug 2007
    How to disassemble this stupid light? I can't find a latch, opening, screw, etc anything anywhere.
    Feels like it's screwed to the wall from behind the light tube.
    It started to randomly turn off after warms up. I guess the tube needs replacing or that thing for these fluorescent light is on its last leg.
    If I can remove the whole light fixture and there's enough wire excess, I would like to replace it with some smart LED lights.
  2. Big Elf
    23 Apr 2009
    The clear cover probably just pulls off with a bit of squeezing on the bottom edge. It could well be just the 'starter' that needs replacing.
    wyx087 likes this.
  3. Mr Happy
    Mr Happy 4 8 15 16 23 42
    25 Apr 2009
    Will the cover not pop off if you can lever it from behind?
    wyx087 likes this.
  4. David
    7 Apr 2009
    Is it definitely screwed to the wall - have you tried pushing it sideways, to see if it is just hooked on a pair of screws?
    wyx087 likes this.
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
  6. legoman
    legoman breaker of things
    28 Feb 2010
    Two end pieces at each end of the bulb should ping off, bulb will be a normal baton twist out one screw fittings should be behind the actual bulb
    wyx087 likes this.
  7. wyx087
    15 Aug 2007
    Ah yes. Got it, thank you everyone. It's the 2 pieces at each end holding the light tube in place, squeeze it and the clear plastic comes off revealing the light tube.
    Then as legoman said, twist the tube into a position to slide it out. The fitting screws are behind it.
    Though I can't find anywhere the "starter" thing. I'm going to try with a replacement T8 8w tube
  8. Vault-Tec
    30 Aug 2015
    haha this is why I love Bit Tech. Not "Look at my new light" but "How do I take it apart? yes"
