Modding *How to* do a wireless thing
Discussion in 'Modding' started by Anthony, 29 Jan 2005.
  1. pumagt500
    pumagt500 What's a Dremel?
    13 Jan 2005
    Thats dumb. My parents never turned ours off. Even If they did turn off, my switch it lets me reset my cable modem throuh the switches IP and when you reset it via the switch it turns back on (or off).
  2. Zero_Distortion
    Zero_Distortion What's a Dremel?
    13 Apr 2003
    the easiest thing for you to do is check whether or not the modem can be acticated via software IE through umm IE (sorry for the pun) You can get cheap DSL modems online for a few dollars these days, I bought a second one I mounted in a PC.
  3. Seth
    Seth What's a Dremel?
    14 Mar 2002
    high speed lines turn off? thats odd mine is always busy doing something 4 me
