Disaster How to fix scratches on Plexiglass?
Discussion in 'Modding' started by BigBig5, 4 May 2010.
  1. BigBig5
    BigBig5 Single Braid Sleeving
    28 Apr 2010
    Hi I have a plexiglass window and it has some scratches on it. I want to know how to fix them.
  2. razerz
    razerz What's a Dremel?
    2 Aug 2009
    How deep are the scratches? I have heard that toothpaste (of all things) and buffing might work on glass and plastic of the scratches are shallow.
  3. BigBig5
    28 Apr 2010
    When I go over it with my finger nail feeling it being Mid-Heavy.
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
  5. bulldogjeff
    2 Mar 2010
    I've heard this as well I think it's because it mildly abrasive , a bit like cutting compound, but I would'nt recommend brushing you teeth with cutting compound
  6. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I have used Autosol for taking out scratches of plexiglass windows with good results, but as anything like this test it somewhere first
  7. Unicorn
    25 Jul 2006
    Tcut, brasso, Meguiars PlastX and Novus polish are all things you'll find in my consumables cupboard for repairing or restoring plastic that has become scored or faded.
  8. DarthBeavis
    DarthBeavis What's a Dremel?
    29 Aug 2008
  9. jesterod
    jesterod What's a Dremel?
    11 Oct 2008
    i would use a wetsand then a toothpaste buff
  10. Cheapskate
    13 May 2007
    If you can feel it with a fingernail, it will need to be sanded out.
  11. 1Razor
    1Razor Living life one day at a time....
    24 Apr 2009
    On our Aircraft perspex we use a system called Micro-Mesh. A variety of abrasive rolls ranging in grades from 1500-12000 (Standard Wet & Dry is between 150-600 grit). The higher the number, the finer the grade. A lot of elbow grease involved but excellent results can be achieved.
    Just be aware you are actually removing the material so it depends on how deep the scratch/groove is before you achieve a smooth finish. Start with the lowest number till it feels smooth then move up to the next highest number, rinse and repeat until it is perfectly clear again.
    At each level expand outward slightly from the damaged area to avoid "dishing". Oh and dremels :dremel: should be avoided - hand work only please.
    Cheaper than replacing a whole perspex panel...
    Enjoy!
