Modding How to get an anodized look, without anodizing?
Discussion in 'Modding' started by m0ng0lh0rde, 10 Oct 2009.
  1. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    I'm looking at possibly painting my Coolermaster Stacker, and what I'd like to do, is give the side and top an anodized looking finish. But, I'm a cheapskate, and I don't want to actually pay to have it anodized.
    I did paint the grill on the side panel with Dupli-Color Metalcast red, which looks quite good, and has put up with some abuse, without chipping. What I'd like, is to go with a red / black theme. Primarily black, with red accents. Problem is, Dupli-Color doesn't have a black Metalcast, the closest they come is "Smoke," which looks like a medium grey.
    Any suggestions?
    I know I could go with a "normal" black enamel paint, but I like the looks of the Metalcast.
    Thanks,
    Jason
  2. Cheapskate
    13 May 2007
    Someone call me?
    I just read a log where MNPCTech used SEM self-etching black primer to get a flat black similar to an anodizing he did.
    Getting transparent black to not look gray is difficult. Have you tried multiple coats?
  3. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Try heat resistant paint.
    Paint it
    Bake it
    Sand it.
  4. m0ng0lh0rde
    5 Jun 2004
    I've not even started painting the side yet, I figured I'd see if I could do what I want, first.
    I also did some checking, the two side panels are aluminum, so if I wanted to spend the $$$ I could likely get them anodized, but the top of the case is likely steel. Used a magnet, it ignored the side panel, but grabbed the top.
    Time to go to the auto parts store, and look around.
  5. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    You could try bluing the top steel.
