Graphics how to get GPU temps??
Discussion in 'Hardware' started by eUphoria, 28 Oct 2004.
  1. eUphoria
    eUphoria What's a Dremel?
    9 Apr 2004
    Is it possible to read the temp on the GPU without using an external physical temp probe?? I.e. something like Mobo monitor?? Ive got a 9800p
    No real reason - just curious to see what load im putting it under! :D
  2. Gecko
    Gecko What's a Dremel?
    29 Dec 2003
    Only nVidia cards have build in thermometers.
    So on a 9800pro, fraid not.
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Cards above an ATi 9800 XT have built in probes, it's been known that you can fit them yourself if you run an LCD that supports probes.
  4. Gecko
    29 Dec 2003
    Aye, but thats ££++
  5. daniel_owen_uk
    daniel_owen_uk What's a Dremel?
    1 Sep 2003
    Depends on the core of your card, if its an r360 then it does have a probe, if its an r350 then it doesn't, you would need to remove hsf to find out.
    Then flash to xt to use probe.
  6. Leeum
    16 Feb 2004
    Not all R360's have the temperature probe, your 9800 Pro needs to have the XT PCB to have the probe.
  7. eUphoria
    9 Apr 2004
    thanks for the replies guys! guess i'll never know what its up to then (r350 core), maybe i can use this as an excuse to buy a 6800 and sell my 9800p?!!!
  8. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Yup. It's a feature of all the XT cards (9600, 9800, X800) that they have temperature monitoring, not even the X800Pro does unless you can flash it to XT.
  9. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    which cards support that feature? and ow do i find the temps? its just somethin thatll come in handy at work
