How to get the most Folding Points from your Hardware
Discussion in 'bit-tech Folding Team' started by Lizard, 23 Apr 2009.
  1. flap15
    flap15 Duty Target
    20 Jun 2009
    Hi Guys and Girls,
    Some what new to this game however I was wondering how to alter the FAH prog so it auto starts when the comp is turned on, since the good lady is unlikely to remember to do it. In addition how do I get the second core folding as well? Running windows XP on a core 2 45nm chip. Thanks in advance.
  2. saspro
    saspro IT monkey
    23 Apr 2009
    To get it to autostart just place a shortcut in the startup folder
    To use both cores you'll need either SMP or run 2 instances
  3. Unicorn
    25 Jul 2006
    Where's babychunder these days? Do I remember him throwing in the towel a while ago?
  4. saspro
    saspro IT monkey
    23 Apr 2009
    He stopped at 10 million points
  5. Unicorn
    25 Jul 2006
    Thought so, I'd forgotten why but I remembered that he had finished folding for now.
  6. babychunder
    babychunder What's a Dremel?
    24 Apr 2009
    Still here, lurking.:thumb:
  7. Norfolk'N'Good
    Norfolk'N'Good Folding Chimp
    23 Apr 2009
    And folding?
  8. Vince_Kinslow
    Vince_Kinslow Folding Millionaire
    25 Apr 2009
    Hows it going bc family well?
  9. babychunder
    24 Apr 2009
    All well thanks. And how is everyone here, what's the gossip?
  10. SeewRipsmem
    SeewRipsmem What's a Dremel?
    16 Dec 2009
    Which version are you running?
    Anyways to get on a sub-team you just have to change your folding username to Spider_Monkey and then youll be part of the monkey federation. If you want to act the part it is welcomed.
  11. Mike_and_Fi
    Mike_and_Fi Two heads are better than one
    21 Dec 2009
    Great article. Particularly for a new folder like myself. Thank you :)
  12. Lehmann
    Lehmann What's a Dremel?
    18 Dec 2009
    Im not sure what setup this site used for there ppd setup. my core 216/260 gets 8500 a day average 9200 on a 353 running 675/1560 even without over clcoking i get more than they say
  13. saspro
    saspro IT monkey
    23 Apr 2009
    I'm getting 6648 from a GTX 280 running an 1888 point project & a -smp 8
  14. Lehmann
    18 Dec 2009
    G0UDG 8800 GTX issues
    when setting up the client's smp needs to be set to idle priority, gpu to low priority soo it can take the cpu cycles it wants. as for your gtx280 what shader speed do you run? find out at what shader speed it corups the client then back off about 50mhz. My gtx260, bfg maxcore55 from bestbuy folds 24/7 with the shader's set at 1560 but it will not play games at that speed. and my fans are set to 80% 51c doing 1888 61c doing a 353
  15. songzila
    songzila What's a Dremel?
    3 Jun 2010
    i have started a team called team_ubuntu. how to get along now? what to do next to get most points?
  16. saspro
    saspro IT monkey
    23 Apr 2009
    First I'd start by ditching your team. Creating a username & joining this team
  17. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Is there going to be an update to the initial post for what hardware is best? I notice there's a few options missing.
  18. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    there is some stuff if you type folding into the search bar i think it's there some where. lists on what hardware is best value/power consumption and things like that:)
  19. dazedandconfused
    dazedandconfused generic babble ->
    26 Jun 2009
    This list needs updating, No mention of GPU 3.
    For those of you who need to know: for fermi (gtx/s 400) you need gpu3. In a recent cpc/bit-tech article it was found that gpu2 should be used for gtx200 series as this provided much better ppd than gpu3.
    EDIT - Just saw the console client is the best gpu there is, Is this still true?? is there even a gpu3 console client?
  20. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    This list really does need updating badly!
