How to get the most Folding Points from your Hardware
Discussion in 'bit-tech Folding Team' started by Lizard, 23 Apr 2009.
  1. Jay88018
    Jay88018 What's a Dremel?
    5 Sep 2012
    Just started today, so learnin as i go along, but put the key in for more points...not sure what its all about, but more points sounds good.
    1 question, while im folding, my gpu is going up to 89 degree's under full load, is this normal ? Movin to a new case soon with better cooling, so hopfully wont be this hot for long, but is that temp damaging to my gpu ??
  2. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    I have an i5-2500K running at 4.2GHz, with a HD Radeon 5850 GPU at stock speeds. Is there anything (bar heavy OC'ing) I can do to push out a higher PPD than around 6,500?
  3. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Is the 6500 PPD between both? As that is very low. The 2500k should net around 15k on its own, I would turn the 5850 off as it is likely draining its resources, using more power and overall providing lower points. AMD cards generally suck at folding.
  4. mikemaher205
    14 Aug 2011
    Will give that a try, thanks.
    Will changing to a Nvidia GTX GPU net much better PPD then, say a 560ti 448 for example?
  5. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Any Nvidia GPU will net more points than an AMD GPU. They simply work better for what FAH is trying to do.
    If you are going to spend cash specifically and solely on folding, CPU power is best if you can afford a new-ish CPU architecture. The higher end chips on socket 1155, 1136 and 2011 are beasts for folding and will churn out far more points for far lower electricity usage.
    Useful link to give you an idea of PPD/£:
    http://www.bit-tech.net/hardware/graphics/2011/04/26/best-graphics-card-for-folding/4
  6. mikemaher205
    14 Aug 2011
    That's a really helpful link, thanks. Looks like an eBay scout around for a GTX 560 ti (448?) is in order.
    Although, the newer AMD cards run differently now, has anyone got an average PPD for a new 7800 series card?
  7. LoudRex
    LoudRex What's a Dremel?
    2 Jun 2012
    Very interesting topic.
    I gonna check some things out :D
  8. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    For best results on an AMD card you will need to run the v7 client, and it will use roughly one core of your CPU. In this regard the linked article is out of date, and AMD folding numbers are difficult to find and compare.
    The usual advice is to buy the graphics card you want for other applications, and think of folding as a secondary consideration.
  9. mikemaher205
    14 Aug 2011
    Interesting info there. I will turn my clients to fold on 2 CPU cores, my AMD GPU and that should leave 1 core free for casual stuff.
    Currently away from my computer and see that my signature says I have scored no points for 2 days... Not good...
    UPDATE 01-10-12: Setting my V7 client to the above has resulted in a new PPD of 18,000. Result.
  10. Ptarmigan
    Ptarmigan What's a Dremel?
    15 Sep 2012
    Hi folks - was pondering turning off the ati gpu's (11k ppd) and setting the CPU back to 8 threads (I7-975EE with lots of headroom) and going for a Bigadv run, but...I can't see how to do that in V7 - can it still be done?
    Cheers.
  11. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    Go Here :)
    tbh i dont think it makes any difference these days as i get so many different WU's with varying PPD
    you need to get rid of the ATi gpu's and get a Nvidia gpu :)
    my GTX560 none TI gets 12-17k ppd on its own
  12. Ptarmigan
    15 Sep 2012
  13. kirk46
    9 Jun 2012
    ok i just googled it and linked the first guide which was adequate for what you were asking....
    beside its still the same guide.
    but the flags dont really work for me....
    ive just got a intel duel core cpu that im testing OC'ing ready for adding a gpu to fold on, ive set the max-packet-size to small and it picked up a nice small 85 base point WU, but the second WU it picked up was 1800+ base point WU, which its going to take over 2 days to complete....
    so setting that flag has done nothing :(
  14. Ptarmigan
    15 Sep 2012
    ah - it's helped me a bit - didn't know how to set the flags before - regarding the graphics cards - would be lovely to afford an Nvidia card but I've a daughter aged 5, another aged 2 and a 2 month old son....PC is low priority process stream just now ;) (I inherited the 975 free from a mate who's a CAD guy and was upgrading) I can't say as the flag itself will help, I'm running at 3.75Ghz on 8 threads and getting estimated 17k pts from a 2.2k work unit (24 hrs turnaround) - I will see if I get any interesting units after this one completes- all about trial and error and learning from everyone else :)
  15. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Can't run bigadv on that processor, need 16 cores now.
    Unless you were willing to do a Linux install and try and trick it, but even then I doubt this CPU is near fast enough.
  16. kirk46
    9 Jun 2012
    thats bigbeta isnt it?
  17. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
  18. mikemaher205
    14 Aug 2011
  19. mikemaher205
    14 Aug 2011
    Wow, over 18 months with no updates!
    So currently, AMD graphics cards are the top dogs for PPD, but what's the difference in PPD between, say, an R9 280 and an R9 290?
    Also, what do the lower AMD cards kick out (R7 or 77XX/78XX)?
  20. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
