How to get three screens working with 2900gt
Discussion in 'Tech Support' started by Neoki, 11 Dec 2007.
  1. Neoki
    Neoki Member
    26 Oct 2004
    Hello, I have been looking at this article (http://www.codinghorror.com/blog/archives/000012.html) about how to get three screens working. Im not looking for it to pan across all three screens, but separate desktops on each.
    The article is exactly what I am looking for but tried what it says and can not get any use from it
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    How are you connecting this up?
    I am sure you require another gfx card to drive the 3rd monitor, as the 2900GT card will only power 2 displays at any time.
  3. Neoki
    Neoki Member
    26 Oct 2004
    Thanks for the reply.
    true, we have tried a PCI Card. My friend wants three different outputs for example DVI HDMI and VGA. Any way possible it does not matter how we end up connecting it. He wants One projector and 2 screens.
    Hope this helps a bit more.
  4. Delphium
    18 Mar 2007
    Ok then it should just be a matter of installing the xtra PCI card and drivers, making sure to boot the pc with all displays connected.
    Windows should detect the screens and give you the option to enable and setup each monitor accordingly.
    Least this is simply the case with nvidia cards, not used ati cards for multi mon much, have found that nvidia's drivers have greater support for multiple screens.
  5. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    its exactly the same with ATI did you try it with a PCI card as that will work
  6. Neoki
    Neoki Member
    26 Oct 2004
    What motherboard will NOT disable the PCI card when using the PCI-Express card
  7. Delphium
    18 Mar 2007
    erm all boards I thought, ive got a 88800gtx pci-e card running along side a 6200le pci card under vista, works fine for multiple screens.
  8. Neoki
    Neoki Member
    26 Oct 2004
    Ok can you tell me how you managed to get this to work with nvidia please
  9. Delphium
    18 Mar 2007
    Insert the 2 gfx cards into motherboard, connect all the displays you wish to run, make sure driver is installed for both cards.
    In windows XP, right click the desktop, select properties to get to the "display properties" page, select the "settings" tab, here you should see multiple monitors numbered for each screen, select a screen and make sure the "extend the desktop onto this monitor" box is checked, click ok.
    In windows Vista, right click the desktop, select "personalize" then "display settings", here you should see multiple monitors numbered for each screen, select a screen and make sure the "extend the desktop onto this monitor" box is checked, click ok.
    Thats it.
    Vista Example...
  10. Neoki
    Neoki Member
    26 Oct 2004
    Is it possible to do this with THREE screens. Needs to be THREE?
  11. Delphium
    18 Mar 2007
    Yes, or even 4 or 5 or 6 (think xp supports up to 12 or 15 displays??)
    Screenie from work pc with 3 screen setup
    Here is my home 4 screen setup, using the same method as stated above.
    :thumb:
  12. Jik
    Jik A Dremel, what is it?
    19 Dec 2007
  13. Delphium
    18 Mar 2007
    Welcome to the forums :)
    Unfortunately that would end up spanning the image across all screens, not separate desktops on each :(.
