Windows How to improve an old photo
Discussion in 'Software' started by Cleggmeister, 12 Mar 2012.
  1. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Hi folks,
    I'm looking for some help "restoring" an old and faded picture. It's been on display in a frame since 1979 hence most of it has faded, though around the border the image has not been exposed hence is looking good.
    I've scanned hit at uber high dpi and am currently messing around with Picassa and Gimp to try and make it better. Trouble is I don't really know what I'm doing!
    Any thoughts or advice welcome!
    Many thanks,
    Cleggy,
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Restoring pictures is sort of a case by case basis which techniques are best used. Most faded will be mostly working with color balance and/or contrast adjustments. If you are able to post the picture, you'll probably get better specific advice.
  3. Gupta
    Gupta What's a Dremel?
    17 Mar 2012
    Any chance the negative might still be knocking around in the loft somewhere? That'll give you something better to work from, or even just a straightforward reprint by a photolab.
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    A little gamma correction does wonders for faded pictures I find- when I scan in my paintings the colours can become very washed out and pale, and contrast/saturation adjustments doesn't quite or always do the trick. Worth a shot ( negative direction to bring out details works in the program I use ( PhotoFiltre free version ) ).
  5. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    Removed.
  6. Cleggmeister
    12 Oct 2009
    Thanks folks, much appreciated. I don't have the eative but I will muck about with those recommended apps.
    Cleggy.
  7. Warner0001
    Warner0001 What's a Dremel?
    20 Dec 2011
    You can touch up it by PhotoShop if you know how it make it or you can just download some photo booth to make it more clearner. Multiple motheds can be applied, the first thing is to google it online but not post here. Good luck for you.l:clap:
  8. Pookeyhead
    30 Jan 2004
    There is no one way to do this. It depends what's wrong. I really need to see it to decide how best to restore it.
  9. Tangster
    23 May 2009
    Post up a preview and we'll be able to give you better advice.
