Hi. I would like to know how to linearize a thermistor. I want to use it to measure a wide of temperatures from 0 degrees C to 70 degrees C. Is there any IC? I don't care for the cost Thank you in advance
now I'm sure he could do that without a PIC. I'd bet maxim has something you can hook the thermistor to that will give you a digital output, from which you can hook a DAC or a digi-pot and get a linear output.
I don't think that there are linear thermistors. I will linearize it programming in Visual Basic. Now another question. How can I calibrate a thermistor? I have a very accurate thermometer (0.001C). So I can measure the resistance for a lot of temperatures. I prefere to make the calibration in visual basic. Thank you in advance... Christos
Easy option is to use a different type of sensor such as LM35Dz or LM335Z, which give a linear voltage with temperature. One snag is, they're both in TO92 cases, so more bulky than most thermistors. There is an equation relating thermistor resistance against temperature, but unless you plot the curve using your 'very accurate thermometer' as a reference and calculate an actual Beta for the thermistor and temperature range you want, results won't be all that accurate.
