Guide How To: Make a cheap (69c) molex pin remover.
Discussion in 'Modding' started by thw01f, 20 Dec 2003.
  1. Vegita
    Vegita What's a Dremel?
    29 Dec 2003
    So it should fit over the female plug, but inside the plastic cover?
  2. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    yes you should put the 'tool' over the metal but inside the plastic
  3. winxp2004
    winxp2004 Banned
    19 Mar 2004
    wow thats class :thumb: cheers dude
  4. CrimsonSky
    CrimsonSky What's a Dremel?
    26 Jun 2003
    Remove the cartidge from a Papermate FlexGrip pen (or similar) and you now have a male molex pin remover. If your a total nerd, it will also clip on your shirt pocket next to the slide rule. :D
  5. CrimsonSky
    26 Jun 2003
    Zap You can find the perfect size square brass tubing at a hobby shop for removing the 20 pin connectors. Usually they are in the architectural model parts section.
  6. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    awsome :rock: It works... have the same pen too! :D :D Now to remove the pesky females...
  7. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
    Whoa Crimsonsky, slide rule??? Man, you must be almost as old as me!
    Nice to see another geezer into modding. :D
    Cheers
  8. CrimsonSky
    26 Jun 2003
    hehehe...oh yeah...I'm up there :hehe:
  9. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    I made the female remover out of a digital coax cable and it worked fine (the one that looks like an audio plug). I had to remove the inner material and I was still having trouble with bending the pins forward. I found out that the tool is not long enough so I cut some of the material from the fat part of the plug to get clearance...
  10. plagio
    plagio What's a Dremel?
    26 May 2004
    What happened to the pictures ? Not that usefull without them.
    Cheers, plagio
  11. Haddy
    Haddy World Domination
    22 Jan 2002
    fired off an email to him to see if he can repost the pics or just send them too me. I dont know what kind of response I'll get as he hasnt even been on the board for 3 months according to the admin panel...
  12. thw01f
    thw01f What's a Dremel?
    13 Sep 2003
  13. Haddy
    22 Jan 2002
    Alrighty updated post with new pic link and reworded title. Happy modding guys :dremel:
  14. ellism
    ellism What's a Dremel?
    10 Sep 2003
    Any one found the 20pin tool in the UK now, for such a prolific mod they are very hard to get hold of, you would think that the companies that sell the actual molexes would sell the tool too.
  15. DrPepper
    DrPepper What's a Dremel?
    26 Aug 2004
    Nice but i didn´t got mine to work unfortunately
    (Bad english?)
  16. thw01f
    13 Sep 2003
    are u using a mono plug. after u cut off the tip, the mono has a longer shaft than the stereo and will reach the tabs on the molex pins
  17. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    for the male removal tool all you need is one wire and chip thingie, removed form the female ones then you just put it over the male and put the wire out, easy cheap and finds a use for old dead PSU cables
  18. iggy
    iggy Minimodder
    24 Jun 2002
    now for iggys way.
    take el cheapo ballpoint pen (bic, whatever)
    remove inside. use inside to remove molex pins. for female molexes all you need to do is cut the pen cartridge down the middle a wee ways.
  19. hed420
    hed420 What's a Dremel?
    26 Sep 2004
    HEH!
    Good thing I found this forum today. I didn't want to spend $9 - $18 on a stupid one time use molex pin remover. Thanks guys :thumb:
  20. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    pics dont work :worried: :sigh:
    went to the other site and they do :D
