Hardware How to Make a CPU: From Sand to Shelf
Discussion in 'Article Discussion' started by Claave, 10 Jun 2010.
  1. Azayles
    Azayles Minimodder
    6 Jan 2008
    I'd LOVE to have a complete edged wafer framed on my wall. Wonder where I could get a scrap wafer? Approach Intel?
  2. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    I'd bet you can get them off ebay
  3. Azayles
    Azayles Minimodder
    6 Jan 2008
    Holy cr@p that's amazing, thank you!
    I looked on ebay.co.uk 'cause I'm from the UK, but I'll set up an account on .com tomorrow and bid on that :D
    Edit: My post made no sense :duh: I'll make a new account on .co.uk and just list the international sellers so I can see the product you listed.
    He has more! They're wonderful!
  4. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    How big a wafer are you looking for? The standard industry 300mm? Cos we have some 80mm ones in the lab at uni. And would you like it patterened? Standard wafers are just highly polished mirrors before the designs are added.
    Azayles likes this.
  5. Azayles
    Azayles Minimodder
    6 Jan 2008
    That'd be fantastic :jawdrop: How much would it cost? I'm in the UK, England. Patterned would be ideal.
  6. Fractal
    Fractal I Think Therefore I Mod
    9 Apr 2010
    Excellent article. Well done!
  7. void
    void What's a Dremel?
    3 May 2010
    Very cool article.
  8. wyx087
    15 Aug 2007
    which uni are you at, may i ask?
    a wafer is probably the geekest thing you can have :) there should be gift shops for this kind of stuff, makes you wonder why Science museum in London doesn't have it.
    wafers are relatively cheap, most cost are from R&D of that particular product. FPGA, that's where it's at, i was playing around with a roughly £2000 Xilinx Virtex late last year, and a £1000 demo unit of Altera Stratix a year ago. you can actually do stuff on those, just need a computer and a USB to the FPGA bard.
  9. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    The cost would be minimal if I can get hold of one, we usually use them to show second year undergrads how IC construction works, from the wafers right through to packaging including how the doping, etching and masking processing works. The circuit we have the masks for is pretty basic and once we make them we either bin them or give a few samples to the students as a souvenir, so if I can get hold of one i'll give it to you for the cost of postage. I'll let ya know.
    Manchester, graduated there a few years back but a Ph.D oppertunity came up in the materials and nanostructures group the guy running it was my undergrad tutor we got on well and I couldnt say no :)
  10. Autti
    Autti What's a Dremel?
    29 Oct 2009
    For those interested the TV show How do they Do it went to Texas Instruments fabrication and explained it well.
    Oh and about the circular saw cutting, they actually use a piece of wire connected to a band saw like machine.
    It's so thin it means they save material as opposed to cutting it out.
    Also, the silicon ingots are so strong they are entirely suspended from a single strand before cutting.
  11. fahdriyami
    fahdriyami What's a Dremel?
    11 Jun 2010
  12. Toka
    Toka Minimodder
    19 Nov 2006
    If you ever pop down to the metallurgy and materials dept at birmingham they have display cases of 300mm Si disks with chips on, as well as some ingots and associated parephenalia :)
  13. dispie
    dispie What's a Dremel?
    4 Jun 2010
    very nice, Article thanks
    enjoyed reading this :)
  14. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    You'd probably need a telescope or uber microscope to see it building anything in the process. I'm pretty sure adding SEM equipment in the middle of building the bars is a recipe for disaster.
  15. Xir
    Xir Modder
    26 Apr 2006
    Very nicely put, and correct for upto 2 maybe 3 layers.
    Anything above that uses the "Damascene" process.
    It's the other way around, as shown in this article actually.
    First you get a layer of silicon dioxid, in which you etch pathways, think trenches. Everything is covered in copper, then you polish back till silicondioxide with copperfilled trenches. Those are your "wires".
    The polishing ensures you have the planarity to repeat this stem multiple times.
    Weeellll, I used to ;) ...now I'm just making silicon wafers :D
  16. sandys
    sandys Multimodder
    26 Mar 2006
    One question I have that I always assumed I knew was what determines you process node size, I always assumed it was min gate length related but one 40nm process I worked on was drawn at 45nm, optically shrunk to 40nm but the gates of the standard cells after shrink were 36nm, so why would you call it a 40nm?
  17. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Ah that sounds pretty cool! If you walk around the D floor in the sackville street building at manchetser (it used to be part of UMIST) we have one or two displays on the wall, one of those has a 300mm wafer but unless you know its there you'd never know. It'd be nice if we could put it all in one room and show it off to any prospective students, but the uni doesnt seem to care :(
  18. PBear23
    PBear23 What's a Dremel?
    4 Feb 2009
    Great article guys. Encore!
  19. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    I always thought the feature size was the average of the width, and the space, in between metal interconnects connecting bit cells in a DRAM if one were to implement a DRAM using this process. I think in real terms it's supposed to be a vauge indicator to the average feature size, so that all manufactures can agree on a terminology standard. And not a definative specification that states the transistor chanel length MUST be 45nm under pain of death!
    Check this link out for some info:
    http://vlsicad.ucsd.edu/~abk/TALKS/michigan-020304.ppt
  20. Azayles
    Azayles Minimodder
    6 Jan 2008
    That'd be fabulous if you could :) Thank you again :-D
Tags: Add Tags
