Electronics HOW to make a LEFT and RIGHT analog VU meter
Discussion in 'Modding' started by imac13, 31 Dec 2003.
  1. imac13
    imac13 What's a Dremel?
    25 Dec 2003
    anyone here know how to make a analog vumeter?
    anyone know where to get analog VU meter. and roughly how much ?????
    how to connect up to the sound card
    and one know of website???
  2. glennd_05
    glennd_05 What's a Dremel?
    6 Nov 2003
    Google it. there are tons of info on VU meters. for schematics just search "VU Meter Schematics"
    -glenn
  3. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Wrong forum my good man, you want modding > modding.
    BUT. Since your username IS imac something and somestuff...
    AND you're asking about a VU meter...
    Whatcha gonna do? :D
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    what exactly are you gonna monitor. you can probably buy the vu meters from say radio shack or online, then they simply have forward V rating probably around 1.9 v for smaller units. If you know your peek input (say 3 v for a hdd Led) then you would find the correct resistor and wire up the vu meter. should be simple enough
  5. cderalow
    cderalow bondage master!
    23 Jan 2002
    can we say wrong forum captain?
    perhaps electronics....
    :idea:
  6. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    made it so... eddie_dane
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    no, you didn't :p
  8. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    4 ideas,
    1 microcontroller (my personal favouarte, as always!)
    would just be one chip, somerthing like a PIC16F870 would be able to power a lot of LEDs, if you need an insane degree of accuracy a 16F877 could power 30 unique states!.
    2 Op-Amps for each frequancy, then to LED. for 10 LEDs 10 op-amps, yukie way tbh
    3 Op-Amp for a certain frequency, then use one of those analouge to digital line drivers
    4 good old Parrallel Port + Winamp plugin, easy as selling 3rd rate junk to a Mac user.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Can nobody (except metarinka) read? :sigh: The man wants some analogue vumeters - that's needle meters, not pretty lights :rolleyes: and to plug into his sound card.
    As metarinka said, first find your meters, which can be anything from about 50uA up to 1mA FSD, then it's a case of adding rectifier diodes to convert the AC music signal to DC and finding a couple of resistors so full volume from the card output sends the needles full-scale. Using the speaker output might have less effect on sound quality than using the line output.
    If you want accurate vu-meter scaling, that gets more complex.
  10. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    I thought by anologue and sound card, he wanted to pick up of the anologue data from his sound card, rather than say output the data from winamp.
  11. Malvolio
    Malvolio .
    14 Dec 2003
  12. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    forgive my ignorance over analouge electronics, but i thought a UV meter was showing just the amplitude?
    If so y not just buy an ordinary needle meter, you might need to amplify the power fluctations + bias, so it says nicely within scale.
  13. imac13
    25 Dec 2003
    but anyone here got the circuit diag or not ???
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A VU meter just has decibel scaling instead of a linear scale. The hard part is calibrating it (if you want the readings to mean something like sound level).
    IIRC the LM3915/6 datasheet shows a front-end op-amp circuit that could be used with needle meters, but, for a simple indicator, a bridge rectifier across the speaker output and a series resistor to re-scale the meter will do, and with a sensitive meter it won't affect sound quality.
  15. imac13
    25 Dec 2003
    so do you know how to link up to my pc ???
  16. cpemma
    cpemma Ecky thump
    27 Nov 2001
  17. imac13
    25 Dec 2003
  18. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Google is your friend. :search:
  19. Toby
    Toby What's a Dremel?
    27 Oct 2003
    I have an analoge meter that used to be part of a voltmeter and its 200ua what does this mean? and does this give me any indication of how i will be able to power it from a 3v mobo hd led header ie what are the calculations i have to make in order to find the right resistor
  20. Pandalet
    Pandalet What's a Dremel?
    29 Dec 2003
    200uA (two hundred microAmps) is (at a guess :lol:) the maximum current rating, i.e. the meter measures currents between 0 and 200uA. (Most) meters are passive devices which don't need a power supply - they just need the input line carrying the current being measured and the corresponding ground line.
    This means that you would hook the meter to your sound line (either a mono line or half a stereo line) with some scaling hardware - I haven't the foggiest what sort of current range one gets out of a sound card, but I'm fairly sure it goes negative (in DC terms), so you probably want to scale it so that your maximum deflection is at 200uA and minimum at 0.
    I can think of (most of) a way to do this with opamps, if that helps any :). It would be easier with a voltage meter, tho.
