Modding How-To Make A Watercooling System
Discussion in 'Modding' started by diabloroker, 11 Jun 2004.
  1. diabloroker
    diabloroker What's a Dremel?
    4 Jun 2004
    How To Make A Watercooling System...
    (2 Methods Of Making It)
    (1st Method Is More Expensive, 2nd Method Is Cheap... Really Cheap)
    -Note: This is a test project my friend has been doing and it has worked, but i am re-amping and re-doing it.
    Recorded Temps: Updated!!!!!
    -P4 2.8GHz
    Idle: 30-36°C
    Load: 39-40°C
    Stock: 46°C
    -P4 3.0GHz
    Idle: 34-36°C
    Load: 41°C
    Stock: 48°C
    Recorded Temps: w/ FROZEN DISTILLED ICE
    Water Temp: 19°C
    -P4 2.8GHz
    Idle: 25-30°C
    Load: 22-26°C
    Price Ranges:
    1st Method=40$
    2nd Method=20$
    Required Equipment '1st Method': (w/ link comming soon)
    - Waterpump of your chose, the better/faster the waterpump is the better. I have used the 'Ehiem 1048 Pump' or 'PowerHead 402'. It is identical to waterpumps including in some kits.
    Link> http://www.marinedepot.com/aquarium_pumps_eheim_universal_hobby_powerheads.asp?ast=&key=
    - Tubes that are compatible with the waterpump, unless u want to do some conversion but this is a high risk with leakage. The one I have used is the one from Frozencpu.com 'Clear Tubing'
    Link> http://www.frozencpu.com/cgi-bin/frozencpu/ex-mis-01.html
    - Waterblocks...the ones you make or the ones you buy. it doesnt really matter just make sure they fit.
    Link> http://www.zfz.com/projects.asp?request=tojjacpu
    - Fittings
    Link> http://www.overclockers.com/articles971/zal7.jpg-
    - Tightener'z or Clamp
    Link> http://www.boltproducts.com/images/tinnerman/tubeclamp.jpg
    - Distilled Water is the best to use. It does not leave any mineral build up and doesnt have to be changed in awhile.
    - Switches are the water pump control
    - Screws
    - Container or Reservoirs used to be used to store water, cool it off, and etc..
    - Radiator or the one you made(link to guide will be uploaded)
    Required Equipment '2nd Method': (w/ link comming soon)
    - Normal Pump (Fishtank, Pond, Etc)
    - 2+ Clear Tubes
    - Clear Container or Shoebox
    - Plastic Bag or Clear Container
    - Rubber Material/Plate
    - 6 120mm Fans or 4 80mm Fans
    - Copper Fins/Heatsink (Old CPU Heatsink, ETC)
    - 3+ Copper Fins/Heatsink 'Matching If wanted, or paint it'(Anysize)
    - 1 Switch
    - Bought Waterblock or made one
    - 4 Fittings for your radiator or buy one.
    WILL BE UPDATED....
  2. diabloroker
    4 Jun 2004
    uhh...hold up on updates
  3. playaa
    playaa Guest
    hope the guids be good.
    by the way: what level of skilles is needed to build this water cooling?
  4. diabloroker
    4 Jun 2004
    uhh lets say.. a 14 year old can make it...because i am one
  5. diabloroker
    4 Jun 2004
    im writing this guide on word then ill change my post... im almost done... its a really good guide so people...HOLD UP!
  6. rankie
    rankie What's a Dremel?
    12 May 2004
    can you pleeeeaaaaaaassssssssssseeeeeee post this guide
  7. diabloroker
    4 Jun 2004
    ill try 2marrow...i had to re write it alot
  8. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Ya WC iw not hard, just scary... :baby:
  9. Colonel Sanders
    Colonel Sanders Minimodder
    25 Jun 2002
    I want to see this. :) I might just have to attempt a ghetto (I'm assuming this is going to be ghetto?) water cooling system, watercolling is just a bit expensive.
    L J
  10. liuh
    liuh What's a Dremel?
    10 Apr 2004
    yeah, watercooling is not hard after you get the plan, but testing is also very fun. Make sure you get all those leaks out :)
    I don't have a watercooling system right now, but i did one for a school project (yeah..hehe) and i tested it for 2 days before i put it in the system. I dont want my stuff to be fried, :)
    GL with the guide, sounds like a good idea.
  11. Skaal-tel
    Skaal-tel What's a Dremel?
    12 Jan 2004
    let me guess, slappin a giant ice cube inside a ziploc bag in the res? ingenious... might not be very practical.... but still a neat idea, if I'm guesstimating right.
  12. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    paciently wainting... especially for the 2nd method :p
  13. diabloroker
    4 Jun 2004
    im on vacation ... so when i get back.. expect it from me
  14. NoRemorse
    NoRemorse What's a Dremel?
    27 Jun 2004
    We are never going to get it... are we?
  15. Goldfish
    Goldfish What's a Dremel?
    4 Jul 2004
    *cough*
    tum tee tum....
  16. diabloroker
    4 Jun 2004
    the guide isnt so good...but it will be up soon
  17. apollyon
    apollyon What's a Dremel?
    20 Apr 2004
    can't wait to see this, i've wanted to try WC for some time now but haven't found to many good resources of exactly how to go about it, so this would be a serious kick in the right direction
  18. sadffffff
    20 Oct 2003
    i really anticipating it because ive always wanted to throw a water cooling system togather, like in a ~1ghz machine just for kicks. and from the sound of things the 2nd method may cover a budget method using many parts i just have laying around home - just what i wanted :)
    hurry up and come back from vacation!!!!!! :p
    naw j/k enjoy yourself man
  19. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    I might be able to write up an article for you guys, i think i still have most of the pictures from when i did my watercooling project.
    I did my setup for around 220 Cnd (90ish GBP) and in my opinion, its better performance wise than any kit you could buy.
  20. hed420
    hed420 What's a Dremel?
    26 Sep 2004
    It's been 4 months already!!! How long does it take to write a giude? Where's the guide?!! :wallbash: I wanna try the FROZEN DISTILLED ICE method.
