Electronics How to make an uninterruptible power supply?
Discussion in 'Modding' started by mattthegamer463, 30 Mar 2005.
  1. mattthegamer463
    26 Nov 2004
    ive scearched the net, and the guides section of bit tech, and i cant find a guide on how to make an uninterruptible power supply. I know i need an inverter for AC-DC, a battery, then another inverter for DC/AC. but i dont know what kind of inverters or where to get them. ill probably use a car battery, that will last for a while, enough time to shut down and will cover me for those 2 second power outtages. can anyone help me out with this project?
  2. iamnafets
    iamnafets What's a Dremel?
    24 Feb 2005
    Depending upon what kind of wattage you need, one of those car inverters might work for the DC-AC, as it's already prewired for voltage etc if I have it right. AC-DC is just a normal transformer, but I'd be thinking you'd use a battery charger. For me I'd have the battery charger wired to the battery which is wired to the inverter and a junction with the wall AC current. The problem I guess is unless your charger supports it, you're just running tons of current through the battery, but otherwise that seems basic enough. There was a hackaday entry for this, lemme find it real quick...
    http://www.dansdata.com/diyups.htm
    That's a pretty in depth article about it, should get you started. Hope that helps!
  3. mattthegamer463
    26 Nov 2004
    i probably only need about <250 watts of power, some of those car inverters are like 300 for about 40 bucks canadian, so ill look at them. and then a modified psu for the ac to dc, and a car battery. this is coming together quite nicely.
  4. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    This PS skips the inverter so your battery lasts 40% to 60% longer http://www.voxtechnologies.com/power_supplies/vtc0144.htm . The hookup would be Charger-Battery-PSU. The input range of the PSU is 9V (discharge end) to 18V (charging over-voltage + some safety) for just this purpose.
    Be careful when you select the charger and battery. At 250W output and 60% efficiency (see datasheet) the PS has 420W input. At 12V that's 35A that your charger has to deliver. If the computer is off a simple charger will dump those 35A into the battery. A lead acid battery likes to be charged at a current of Ah-rating/10h at most, otherwise it dies fast. That means the battery has to have at least 350Ah, or you need a computerized charger that can detect the charging level to turn down the current.
