Windows how to move screenshot to where I want to put it
Discussion in 'Software' started by tony007, 10 Mar 2013.
  1. tony007
    tony007 What's a Dremel?
    9 Feb 2011
    If I save a screenshot to paint how do I move it from there to where I want it? Thanks.:D
  2. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    File - Save As and choose a location and a name.
  3. sourdough
    sourdough Minimodder
    17 Sep 2010
  4. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Assuming you are using Windows 7, instead of using Print Screen to take screenshots, use the Snipping Tool where possible. It allows you to select parts of the screen and can save the screenshot there and then. If you are using a previous version of Windows, then you might find some software that does similar, or you have to stick to the print screen method. Of course, most major Linux distributions have had this support for years, so if you are on that then look for a package that adds it in.
  5. adzc1987
    adzc1987 Minimodder
    19 May 2011
    note Alt+Print Screen will only copy the active window.
