Hardware How to Overclock the Intel Core i5-2500K
Discussion in 'Article Discussion' started by Claave, 7 Jan 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Cei
    Cei pew pew pew
    22 Mar 2008
    Nice to see EFI finally being used, no more wall of bright blue! Took their time though, Apple have been using EFI since 2006, and even HP were using it back 2002 for Itanium 2.
    Plus that's a tasty OC. Hope the rest of SB is this good, or is this the standout CPU?
  3. Claave
    29 Nov 2008
  4. wyx087
    15 Aug 2007
    how's this new load-line calibration implemented?
    with i7 860, it's horrible and very unreliable. it sustains voltage at what you've set in the BIOS, however, due to Intel's design spec, voltage drop should be expected. so, when try to overclock the 860 with turbo mode v2 enabled, you will get random crashes when running single or multiple threaded applications. end of the day, disabling LLC and sticking to Intel spec is the best way forward.
    other useful piece of information you could have included in this great article is how to test turbo mode stability. i found running overnight loops of CPC benchmark works great, because it have a lot of different processor load levels to test all possible cases.
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I have differing understandings of Vdrop and Vdroop...
    Vdrop = The difference between voltage set in the bios and the actual voltage - loadline calibration makes the actual voltage match that set in the bios.
    Vdroop = the amount the voltage drops as the processor comes on to load.
    These are definately two different things, as i have done hard mods for both of them in the past.
  6. robump
    robump Minimodder
    30 Sep 2010
    That efi on the asus look pretty nice!! Bit of a difference from the old bios!
  7. Xir
    Xir Modder
    26 Apr 2006
    With your Overclock, is "Turbo-boost" still enabled?
    (In other words, doe the CPU still ramp down when idling, and Up when needed, just to a higher level?)
    Secondly, if I look for an Overclock WITHOUT touching the Voltages...I might probably just as well go with the on-motherboard-auto-overclocking-features, such as the Turbo-Key-II on the Asus, right?
    If not, what would be a recommended stable overclock without touching the voltages?
  8. wyx087
    15 Aug 2007
    In my experience, loadline calibration also reduces Vdroop and eliminates Vdrop. What I don't understand is that both are pretty much constant for each motherboard, so why can't people simply set a higher VCore in BIOS?
    Intel spec does allow for some Vdrop and Vdroop, if those motherboards are outside that spec, then they will not be on the shelves.
    Not following design spec by eliminating Vdroop when the processor is underload will result in unstable half or lightly loaded processor, Due to turbo boosts.
  9. DbD
    DbD Minimodder
    13 Dec 2007
    Nice guide, I'll keep this handy for when I get my hands on a cpu :)
  10. Margo Baggins
    28 May 2010
    I completely agree :) I was refering to the article where it states some people wrongly refer to it as Vdroop - when in my experience, that is Vdroop. I think i misread it or the article is slightly misleading there in terminology - but is no biggy :)
  11. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Where and when can we buy these processors? I cant find them anywhere.
  12. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Everywhere. Monday.
  13. bogie170
    11 Aug 2008
    Even McDonalds?!!
    Fingers66 likes this.
  14. SaNdCrAwLeR
    SaNdCrAwLeR What's a Dremel?
    1 Feb 2008
    even in the garbage bin behind that italian restaurant over there! *points*
  15. bogie170
    11 Aug 2008
    Thanks for info i'll keep my eyes open on monday!
  16. Fingers66
    30 Apr 2010
    :D
    To elaborate, try the following places on Monday...
    CCL Online
    Scan
    Overclockers
    Aria
    Novatech
    Yoyotech
    Ebuyer
    ...and compare the prices. Don't forget to include the delivery options when comparing.
  17. mecblade
    mecblade 14 year old Technophile
    12 May 2010
    *sighs at a fellow southamptoner's comment*
  18. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Not at dabs.com then? :)
  19. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    10KHz isnt equal to 0.1 MHz :p good review though, glad to see the premium boards arent as expensive as I feared. Come payday its a 2500k and a asus mobo for me :D
  20. frontline
    24 Jun 2007
Tags: Add Tags
