Windows How to reboot a computer?
Discussion in 'Software' started by wildegnux, 25 Jun 2007.
  1. wildegnux
    wildegnux What's a Dremel?
    23 Jun 2007
    So I've got a win2003-box at home that I use VNC to control. Everything has been working fine with it for the last 1,5 years but a few days ago it decided it was a good time to reboot (windows update maybe...) but it somehow crashed along the way and is now only displaying "Windows is shutting down..."
    I'm currently about 500km away from the computer and will be for the next two months so I don't have physical access to it.
    Does anyone have any bright ideas to how I can make it reboot?
  2. Matkubicki
    Matkubicki What's a Dremel?
    18 Jan 2005
    call someone nearby maybe? :hehe:
    Other than that I doubt there is anything that can be done. Unless you can somehow get the power to the building its in cycled.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    Yep, physical access... :D
  4. Krikkit
    21 Jan 2003
    The ultimate VNC conundrum! :p There really is no answer except to get physical access tbh.
    Aren't there some IP-based KVM's which connect to the mobo headers in case of this?
  5. Sp!
    Sp! Minimodder
    6 Dec 2002
    you can get network enable PDU (power distribution unit's) so you can turn power on and off remotley but uinless you already have one installed your only option is someone with physical access
  6. Glider
    Glider /dev/null
    2 Aug 2005
    ...or remote reboots
    But that all has to be installed before the dirt hits the fan ;)
  7. wildegnux
    23 Jun 2007
  8. Glider
    Glider /dev/null
    2 Aug 2005
    administrator
    X
    :D
  9. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    Best post ever! :)
    AFAIK you cant do anything from within VLC, though if you have one of them things on your mobo which makes the computer turn on with certain network activity maybe that could be abused to trip a restart ?
