Xbox 360 How to record xbox 360 gameplay?
Discussion in 'Gaming' started by krazykid035, 28 May 2010.
  1. krazykid035
    krazykid035 Entrepreneur
    13 May 2009
    Title says it all: How can I record my xbox 360? Do I need to get a separate video card for my computer? External recorder? Etc...
    Thanks
  2. TCoZ
    TCoZ Buffalo buffalo buffalo buffalo...
    3 May 2010
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Do you have a dvd recorder or HDD/DVD recorder in your lounge cos u could record to DVD and then transfer it to your pc.
    We have done that by accident when my lads was playing the Wii, wouldn't be HD res so depends what you want.
  4. shigllgetcha
    shigllgetcha Come at me bro
    3 Mar 2008
    search dazzle in google. its only standard def
    to the best of my knowledge there isnt a simple way to record in HD though.
    with the dazzle i think you use rca and get a Y plug for all three cables, one set to tv one to the dazzle box. i think maplin do them aswell
    im not sure if you could just connect the rca plug it into the dazzle and run the HDMI to the telly, i think it only runs video to one at a time but i havent checked.
    the dvd recorder with HDD would prob be the easiest as Mr Bag says
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Hauppgauge makes an HD PVR, it's very popular among the youtube xbox people.
  6. shigllgetcha
    3 Mar 2008
    shows what i know lol
  7. joedpwd
    joedpwd What's a Dremel?
    31 May 2010
    I Know quite a bit about Capture Cards.
    You can go for the cheaper standard definition capture cards which are mainly the Dazzle DVD Recorder and the Easy Cap which are around £0 - £50. MY freinds got a Dazzle and posts on Youtube and quality is alright I suppose.
    Or if you really need high quality videos and you've got lots of cash go for either:
    HD PVR - A Separate box which records in HD - £170 off Amazon.
    Black Magic Intensity Pro - A internal PCI-E Expansion card which is probably the best card within a reasonable price range. Machinima on Youtube use this one quite a lot. - £160 off Amazon.
  8. flukielukie
    flukielukie The Cool Guy
    3 Jun 2010
    More and more games are having in-game capture solutions for example Halo 3 with Bungie Pro or previously GameVee could grab videos off your file share and upload them to the web, I used it to make a machinima and you could too I imagine, Just Cause 2 for PS3 has this, it's a shame that the 360 doesn't yet.
    I hope that in the next generation of consoles they all have video recording and screenshot taking built in and stored on the cloud.
  9. Neoki
    Neoki Minimodder
    26 Oct 2004
    Hey use the HD-PVR, Here is a sample (I know the spelling errors are there)
