Windows How to repair Windows Vista without repair disk?
Discussion in 'Tech Support' started by arachan, 9 Mar 2012.
  1. arachan
    arachan What's a Dremel?
    21 Oct 2011
    Hello,
    A relative wants me to fix their laptop that runs Windows Vista. When I try to boot it it comes up with an error saying that I need to use the installation disk to repair \Boot\BCD. Neither me nor my relative has a Windows Vista installation disk. How can we fix this problem? I may be able to get hold of a Windows 7 install disk, would that work as well?
    Thanks in advance :)
  2. longweight
    7 May 2011
  3. DeafGamer2015
    DeafGamer2015 Minimodder
    5 Jun 2010
  4. longweight
    7 May 2011
    Ah my bad, I actually can't find a live link for it!
  5. DeafGamer2015
    5 Jun 2010
    Don't worry about it, longweight..
  6. DeafGamer2015
    5 Jun 2010
    Any update on this?? I'm trying to find Vista ISO..
  7. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    has anyone seen a windows anytime upgrade disk, it's normally supplied with oem machines.
  8. lucas4
    lucas4 What's a Dremel?
    21 Feb 2011
    I'm sure a vista ISO should be easily obtainable with a Google search ;)!
    Don't want to open up a dodgy topic, but my take is that if you own the key, you have a right to get the installation apparatus by the means you find relevant.
  9. RichCreedy
    24 Apr 2009
    my take on this is that dodgy downloads MAY come with added extras that you don't really want
    Apophis54 likes this.
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Any outcome on this? If not, drop me a PM I might be able to help.
  11. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
  12. Teelzebub
    27 Nov 2009
    If you're prepared to pay post I could send you a copy of a Vista disk
    noizdaemon666 and Apophis54 like this.
  13. arachan
    21 Oct 2011
    Hi guys,
    I actually got a disk of a friend in the end, sorry about not reporting back. I see there are some links to download the Vista iso for free, but does anyone know if there is a Vista Repair Disk? Does such a thing even exist? Just out of curiosity...
    Thanks,
    arachan.
  14. t4n6o
    16 Aug 2011
    not sure, i thought thast the first link i put on was, but it cost $9.99 i think
  15. noizdaemon666
    15 Jun 2010
    Some of those links have dead downloads t4n6o, that's the issue I kept having when Googling.
    Arachan; I think you'd be better off with the actual install disc. Not sure how a repair disc would function.
    For anyone who wants it, I do have a 32 bit ISO available. As most know, it'll cover any edition of Vista but only 32 bit architecture.
    DeafGamer2015 likes this.
  16. DeafGamer2015
    5 Jun 2010
    I trust him.. he's very reliable, everyone!! Noiz, have some rep!!
    noizdaemon666 likes this.
  17. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    I think a "repair disk" is burned on and specific to a particular PC. If you just want to make a generic repair, just grab a full ISO.
    I had the same problem a little while ago when part of my harddisk died, killing a bunch of core Win7 files. I had my license key, but have lost the installation disk. In the end, I downloaded a new full ISO (making sure it was for a version that matched my key), burned it on a different computer, popped it in the drive and Windows auto-detected it and gave me the option to repair. Half an hour later everything was running perfectly.
