Modding How to reuse an old waterblock
Discussion in 'Article Discussion' started by Lizard, 11 Jul 2009.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. Jipa
    5 Feb 2004
    Nice an simple.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    3rd paragraph, first page: "charging a ludicrous amount of them"
    You mentioned drilling out motherboard holes, is this even possible to do?
  4. capnPedro
    11 Apr 2007
    You seriously need a new Engineer's Square!
  5. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Yay, finally more modding articles! :D
  6. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    Simple and useful :D
    Great article
    An it's nice to see the modding comunity slowly rising again! ;)
  7. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    you have to try harder if you want to date a waterblock.
    hint: they like the beach, lots of water, lots of sand. the only thing you have to bring is the paper.
  8. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Nice article :thumb:
    Yes it is possible, the holes in the motherboard are surrounded by about 1mm of unused space to prevent stress from the screws messing it up. You could make them bigger, but it is risky.
  9. -EVRE-
    -EVRE- What's a Dremel?
    12 May 2004
  10. ry@n
    ry@n Minimodder
    31 Aug 2005
    Great article, im sure its going to help a lot of people. If I wasn't so lazy I might have done something similar with my old Danger Den 775 block.
  11. mayhem
    mayhem Owner of Mayhems
    12 Sep 2008
  12. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    nice guide but typically any good block now and days and from about up to a year ago will allow you to hook up other mounting hardware so its not really that necessary anymore unless you have a pretty old and I mean old water block. But still it was cool to read. :)
  13. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    LOL yeah, i did this 4 years ago with one of Cathers SS Cascade blocks.......still got it actually
  14. M_D_K
    M_D_K Modder
    3 Apr 2002
    I got some custom plates kicking around also :) & have my SS Cascade still as well paul good block that :).
  15. ry@n
    ry@n Minimodder
    31 Aug 2005
    Im desperate to get my GTX 285 under water but full cover blocks are stupidly priced due to the sheer lump of copper and build costs involved, Im considering using a GPU only block and cooling the VRAM with some RAM sinks but this will probably cost £30-40 all in and a full block is only about £20 more... grr!
  16. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    very nice article
    glad to see bit-tech get back to more modding articles
  17. Rogan
    Rogan Not really a
    6 Oct 2003
    That's Hong Kong's finest digital caliper! It cost me at least £5.
  18. Rogan
    Rogan Not really a
    6 Oct 2003
    Oh wait.... the square... yes it's a bit knackered. Then again it's really quite modern in comparison to my spirit level, which is so old it's made of wood.
  19. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    The most important part is the measurements. for the different sockets holes. Over at Xtreme systems there is a handy guide made by duniek with mounting hole dimensions for the Intel LGA775 / LGA1366 / 478 / 1160 and AMD AM2/AM2+ / 754/939/940 and Nvidia GPU GTX260/280 / 8800 / nv7,8,9 series and ATI 4870x2 / 3870x2.
    Saves a lot of time ;)
  20. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Nice article! I don't have any wc blocks yet, but most likely I'll be starting used and making a new/compatible bracket thanks to these tips.
    +3 on the new modding articles... now to read MOTM! :D
Tags: Add Tags
