Windows How to save screenshots
Discussion in 'Software' started by nick01, 3 Mar 2005.
  1. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    Problem:
    I am working on several control computers (W2000 and XP Pro) where I have to save quite a number of screen shots needed to write user documentation. The procedure is:
    1. Hit "print screen"
    2. Switch to some image processing software, currently just Kodak Imaging as you get it with Picture CDs
    3. Open new JPEG file
    4. Paste screenshot
    5. Save file
    6. Switch back to the original application
    Doing this just once is easy, but after the 101st time it gets annoying and distracts from the real work.
    This is what I would like to do:
    1. Right click on screen
    2. Select from pop-up menu "Save screenshot"
    Done, screenshot is saved to a file with a default name in a default folder. Name should include a timestamp and file should have JPEG format.
    Question:
    Does anyone know how to do this without installing much software (admin won't let me)? I know how to tinker with the right click menu in MS Word, but can this be done for the system so the right click menu point comes up in any application?
    Thanks for any advice
  2. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    There's a program called "PrintKey", I believe it is. Basically does what you're describing..just not a right-click thing. Believe it's a toolbar program.
  3. nick01
    6 Nov 2004
    Thanks fot the hint. It looks simpler than the current procedure.
  4. Zephyr
    1 Oct 2004
    No problem mate :)
  5. fizban
    fizban What's a Dremel?
    11 Jun 2004
    there's a program called 'HoverSnap' that is really good, it's what I use to do all my screen caps for documentation I write at work.
    It gives you a couple of options like print entire screen, print current active window, and print custom. You can also set up where it saves the pics. :thumb:
    -Fiz
  6. Wesker
    Wesker What's a Dremel?
    26 Sep 2004
    Gadwin Printscreen is the best program I have used, you can set the program to resize the images when it saves them and set the filetype and quality they are saved in...
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    do these, or others you can name, include any video output?
    i.e. if winamp was playing, would the screen shot show the video or a black box?
  8. Wesker
    26 Sep 2004
    I know in the case of WMP10, if you turn video acceleration all the way down you can take screenshots of the video, other than that the freakish movable images shows up...
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Another free program to check out is 'Capture', you can set hot-keys to capture full desktop or just the active window, or just click on the tray icon. Saves a time-stamped bmp file wherever you set. :thumb:
