Guides How To Sleeve a D5 Pump
Discussion in 'Article Discussion' started by bit-tech, 11 Feb 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    Keep up the good work. :D
    Molex are so big and clunky, you can push the pins in with a paperclip. I've never used a tool on one.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    My old go to used to be a ballpoint pen cartridge that I chopped the end off haha, worked flawlessly until I lost it. Tried making another but it seems I must have lucked out with the cartridge diameter the first time.
  4. avictord
    avictord What's a Dremel?
    27 Jan 2019
    A good guide although the sleeving within the pump was not demonstrated i.e. heat shrink. I understand why it was a molex connector although pumps are better off with a fan connector for motherboard control or possibly a fan controller. Interested in your thoughts.
  5. Vault-Tec
    30 Aug 2015
    Good guide. Kudos for doing it in pics too and not being lazy.
    I must say I was a little sceptical (sorry) when you launched the YT channel but I like the way it's going.
  6. Maki role
    9 Jan 2012
    I tend to go straight to the PSU, nice and reliable and very simple, plus means it's easy to power externally when filling the loop.
    Well when you set yourself the target of trying to become the top PC modding channel on YT, gotta put out the content!
    Vault-Tec and MLyons like this.
Tags: Add Tags
