Other How to test my computer components? - Weird issue
Discussion in 'Hardware' started by AlexB, 1 Mar 2012.
  1. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    Hey guys,
    I've got two PCs at home. One downstairs for 'gaming' and one upstairs for 'gaming'. ;)
    Anyway, The upstairs one is primarily used for sim-racing. Recently (last 3 months or so?) I've noticed that I get really guff framerates in my favourite games - rFactor mainly. I switched back to 1 monitor last night (from three) to see if it was a resolution issue, but it didn't help. I get 23-26 FPS at the start of a race with 20 AI cars.
    I have reinstalled windows, all drivers, done windows update and tried again, with the exact same FPS.
    I just tried it on my PC downstairs, and get 200-290 fps with the same car, same track and same amount of AI.
    I tried swapping the graphics cards around and the FPS didn't change - in both cases the FPS is the same.
    The spec of the PCs are:
    Upstairs:
    i5 2500k (tried both standard clock and @ 4.2)
    ASRock mobo (decent one)
    16gb ram
    2tb hitatchi HDD (sata3) (brand new yesterday, a 1gb seagate before that)
    AMD 6970
    Creative XFi PCI-E
    Downstairs
    i7 2600k
    Gigabyte mobo
    8gb ram
    128SSD (system), 1.5tb seagate (games)
    AMD 7970
    Creative XFi PCI-E
    In addition, I have recently changed the following chasing FPS:
    Graphics (started with 5970, then went to 2x 6970 CF, then 2x 580 SLI, now back to single 6970)
    Motherboard (when trying to get CF to work properly)
    Ram (went from 4gb, to a 8gb kit now to a 16gb kit)
    HDD (old 1tb was old, so replaced for new)
    PSU (just incase)
    So, what can I do to check what might be wrong? Anyone got any ideas? I used to get 100-120fps on the upstairs PC before I upgraded - back then it was a i7 860, 4gb ram, and a 5970. Very weird.
    Cheers in advance.
    -al
  2. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    That is very odd indeed. Have you checked the powertune thing in Catalyst?
  3. Deders
    Deders Well-Known Member
    14 Nov 2010
    So since it started being slow, you've changed everything pretty much?
  4. AlexB
    22 Dec 2005
    Yep. I also tried my 2600k in it earlier, and the ram from down here and it made no difference.. So, very weird. Can't think what might be causing it?
  5. boltonuk007
    boltonuk007 New Member
    29 Sep 2011
    try a different monitor? might be a frame rate issue with the monitor
  6. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    did the game get updated or patched or did you install any new software? Have you run your antivirus program's scan?
  7. AlexB
    22 Dec 2005
    Game is 6 years old, was updated in 2008. nothing since.
    Not run any antivirus, but did replace the HDD (and didn't re-install the old one back in)
    Tried 4 diff monitors. (one HDTV, three monitors)
  8. mrbungle
    20 Sep 2004
    From what it sounds like is the only consitant component between all your problems is the motherboard?
  9. Deders
    14 Nov 2010
    Motherboard was switched out at some point
  10. AlexB
    22 Dec 2005
    Yep, mobo was switched too :(
  11. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Does the problem occur when using a different game? Is it something unique to that game? Have you done all drivers including chipset etc?
  12. AlexB
    22 Dec 2005
    All games seem shitty - 40fps in crysis2, for example.
  13. Deders
    14 Nov 2010
    Sounds about right, what does your other machine give you?
  14. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    It sounds software related. Have you got a spare HDD to put Windows on with a game to test it?
  15. AlexB
    22 Dec 2005
    I get a solid 60 (vysnc'd) on the other machine (with either graphics card installed).
    I've tried a new HDD with a fresh install, full windows update, all updated drivers and fresh install of the games.
  16. Deders
    14 Nov 2010
    Is triple Buffering Enabled?
  17. noizdaemon666
    15 Jun 2010
    What was the board you had before your current ASRock? And did everything work fine FPS wise on your old board? Which PCI-E slot have you got your graphics card in?
  18. AlexB
    22 Dec 2005
    Nope the previous board had the same issues too. The previous one was a gigabyte one, I think. can't remember.
    I've got the card in slot1 atm, but also tried slot2.
  19. kenco_uk
    28 Nov 2003
    Have you checked the PSU? /sorry missed it in OP.
  20. noizdaemon666
    15 Jun 2010
    Have you checked that the GPU is running at 16x not 8x or 4x?
