Graphics How to turn off igpu on laptop
Discussion in 'Tech Support' started by enfluence, 30 Apr 2013.
  1. enfluence
    enfluence Member
    31 Aug 2009
    So I just got my laptop. It's got a gtx 680m and it always chooses the igpu over it. I've uninstalled the intel hd drivers and now I've got no screen... I've had this problem before and I needed to reformat it to fix it. Is there anyway to fix this?
    Laptop is the p170em
  2. GeorgeStorm
    16 Dec 2008
    Are you sure it's not just choosing the igpu over it when on the desktop etc?
    How are you checking which it's using?
  3. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    I would want the frugal igpu being on on the desktop instead of a power guzzling (i love that word) discrete gpu. As long as it switches when it's needed, of course. Does it?
  4. enfluence
    enfluence Member
    31 Aug 2009
    I know because I've had this issue before and when i go to install the nvidia drivers it says theres no compatible hardware found yet in the bios theres the 680m right there. I need to know how to make swap over the igpu because right now theres a sceen with low res...these integrated graphics cards are ****ing awful...
  5. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Automatic switching between discreet GPUs and integrated has long been a bit unstable in Windows. Are you saying the 680m wouldn't even kick in when really needed such as gaming?
    As your laptop is (How do I say this nicely) a generic machine I'm assuming you'll have to use the nvidia software rather than anything specific to your machine.
    You could try looking at:
    http://www.intel.com/support/graphics/sb/CS-031103.htm
    For info: Apple who (love or hate them) are not ones to introduce software complexities when related to hardware capabilities have got graphic switching licked in OSX, it always works perfectly and seamlessly. But they don't support it under Windows, you always get to use the dedicated GPU.
  6. enfluence
    enfluence Member
    31 Aug 2009
    Thank lol seems i had to set it to always use the nvidia gpu in the nvidia settings as it didn't swap over....strange also is how it needs the igpu intel drivers to even run the nvidia ones...Guess that's just how notebooks work
