Apple How to uninstall iWork '09 trial, keep iWork '08?
Discussion in 'Software' started by AT0MAC, 5 Feb 2009.
  1. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
    I want to try out if iWork '09 is a upgrade I want to invest in.
    The thing is that I don't seem to miss anything in the current '08 edition so I might think the outcome just will be that I uninstall '09 after the trial period and then falls back to '08..
    But how do I do that?
    Do I have to install '09 on top of '08, unstall it and then find my discs to install '08 from the start afterwards?
    ...or do they get into the mac as two seperate "suits"??
    As long as I can't find the answer I have not tried to install it yet
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Where did you get the trial as I don't think its on the apple website unless I missed the blatantly obvious.
  3. AT0MAC
    8 Jun 2008
    Hmm that's odd...
    You're right!
    ...it was of course iWork i ment, my bad - going to change the title right away!
    :thumb:
  4. Firehed
    15 Feb 2004
    iWork08 is installed to /Applications/iWork '08. 09 is installed to /Applications/iWork '09. The two function completely independently of each other, so if you don't find the need to upgrade then just drag the whole 09 folder to the trash and be done with it.
  5. AT0MAC
    8 Jun 2008
    Oh... That's nice :clap:
