How to update BIOS?
Discussion in 'Tech Support' started by keir, 7 Mar 2007.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    I need to update my BIOS for dual core, I dont have a floppy drive, and I cant find a program that can do it windows, for my DFI NF4 SLI-DR
    I did try doing it via my USB stick, but it gives me the error "NTLDR is missing"
    So any other ways?
  2. DougEdey
    5 Jul 2005
    Use nero to make a bootable CD. Put the floppy contents onto it. Boot, jobs a goodun
  3. keir
    5 Oct 2003
    What just with the 3 files (from the mobo BIOS site)
    AUTOEXEC
    AWDFLASH
    NF4LD406.BIN
  4. DougEdey
    5 Jul 2005
    Yea, Nero (at least the version I have) has built in DosLINUX image files. When you make the bootable disc you can put those files on your C:\ in a folder, then browse to it and run,
  5. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    in theroy you could format a pendrive as a boot disk, then use usb as first boot in the bios.
    i havent done that but at a quick glance it seems the easiest method,
    remember to copy the bios on to the pen drive after formatting it! lol
  6. Guest-16
    Guest-16 Guest
    WinFlash? If it's an award bios it should work fine.
  7. Burnout21
    9 Sep 2005
    very true. i dont know why but i was thinking of a way to flash my GPU bios at the time of writing my post above, so i was thinking i couldn't be done in windows.
    Iv used winflash to update my DFI in the past so u'll be fine
  8. keir
    5 Oct 2003
    Thats the first thing I tried I got an error saying its not an award bios, its phoenix.
    Yet one of the first links when you search for that on google is...
    I've done a boot CD. and it gets to DOS, the path is on the A:/ drive tho, not sure if thats suppose to happen, I then type AUTOEXEC, it says its not a command.
    So I obviusly dont know what im doing lol.
  9. DougEdey
    5 Jul 2005
    Where did you put the BIOS files?
    I reccomend to put them on C:\BIOS
    then when you are at the A:/ prompt:
    Code:
    C: <enter>
    cd BIOS <enter>
    <command here> <enter>
  10. keir
    5 Oct 2003
  11. DougEdey
    5 Jul 2005
    Where did you put them though? I can't see the download as I'm at work, but I'm assuming it'll be from a ZIP?
    If it's just the BIOS.bin file then put that in the C:\BIOS directory with the pheonix flashing tool.
  12. keir
    5 Oct 2003
    The files are on the CD Its booting into DOS with.
    but what do I type when im in DOS?
  13. DougEdey
    5 Jul 2005
    just what the instructions tell you to. normally it's
    <program_name> <bios_version>.bin
  14. keir
    5 Oct 2003
    Phew finaly done it, I found a Utility that you can boot on a Bootable cd and just select the bios you want to install easy. :)
