Electronics How to ... ?
Discussion in 'Modding' started by [DE]FreD_S, 3 May 2002.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Hi !
    How do I find out what resistor I have to use, if want to cut the power in a curcuit ? For example if I want to cut a 12V line to 7V ? What's the formula to use for this task ? Sorry for my crappy English, I have to get used to it again ...
    Cheers
    [DE]FreD_S
  2. dakar
    dakar What's a Dremel?
    6 Mar 2002
    I don't believe you can figure that out without knowing the amount of current required by what ever needs the 7v.
    Assuming this is for use in a puter... why not use both the +12 and +5 leads in a molex connector hook the + lead to your circuit to the yellow and the - lead to the red and viola +7v.
  3. viridius
    viridius What's a Dremel?
    7 Apr 2002
    If you are planning to run a medium power device, the 12/5 trick isn't recommended. Use a 7807 regulator chip. Simple setup. 12V in one side, middle to ground and 7V out the other side.
