Hower you Today !! Welcome ,.. OK , How I can Know that This windows on my computer 32-bit or 64-bit !! How to know !! by steps or tool or some way ?? I want to know , Thanks , CK
If you type "winver" into the Start->Run box it will tell you about which version of Windows you have installed. If you don't know which version is installed then it will almost certainly be 32-bit however. edit:too slow!!
You have to BUY a 64-bit edition and install that in order for you to actually have a 64-bit edition! Once you install the 64-bit edition Windows then Windows will take use of your 64bit cpu.
If you think you should run 64-bit XP, think again. It sucks balls bigtime cos its buggy as hell and poorly supported for drivers etc.
Where did you buy your copy of Windows from Computerking, and did it not specify which version it was when you were buying it?
lol ,, thanks thanks guys I was want get Vista 64-bit so I WIll order it by night today so if its suck like airchie said !! I will get vista 32 -bit !!! But 64-bit faster !! SO Vista unlimit 64-bit or vista unlimit 64-bit??????
DAmit SORYYYY forgive me guys !! SO Vista unlimit 64-bit or 32-bit !!! ( for mt Sig.. HArdware ) SOrry .
definately 64 bit vista, 64 bit is the future, and soon enough 32 bit will be far outdated =P The real question is, what's the x86 version? *stumped* (haven't really read bugger all about vista, and apologies if i end up hijacking, it's none intentional but might benefit you too!)
There is vista 86-bit !!!!!!!!!!!!!!!!!!!! I never saw this !!!!! Tell me !!! I'm interesting !! BTW : done order 64-bit
mean its hardware not software !!!!!!!!!!!!!!!!!! COOOOL YOu have cool information guys But I still The COMPUTER KING
x86 just refers to the 32bit architecture used by PCs- they're still 32bit, and x64 is used by 64bit PCs and Macs. <A88>
