Modding How would I hook up a CU20025SCPB-T20A VFD
Discussion in 'Modding' started by error.ini, 10 Oct 2003.
  1. error.ini
    error.ini What's a Dremel?
    25 Aug 2003
    http://www.qscomp.cz/Pdf/CU20025SCPB-T20A-05.pdf
    I bought this VFD above, and was wondering if I could hook it up to serial? Serial is only like 1 wire, which would be ideal for where it's going to go. Can someone tell me which pin (if any) can hook up to serial?
    1 more, thing, it seems to have 2 different places to power it, 1 is like a 3 pin fan header, can I just use that source for power, and not the VCC with the 16 pins?
    Here is an image of it
  2. pranks7er
    pranks7er mange tout
    25 Dec 2002
    go to LCD FAQ in electronics check there :D
  3. error.ini
    25 Aug 2003
    The pin setup is different than it shows in the VFD serial review. On Noritake's website says "This
    can be RS232 for POS, RS485 for transportation and
    8 bit parallel for instrumentation.", but on all of the guides, I see different names for pins.
    *EDIT* - It seems that it's only a parallel, but still, some pins don't match with what I see in the guides. Thanks.
  4. dario87
    dario87 What's a Dremel?
    16 Oct 2009
    display CU20025SCPB-t20a
    hi I´m German Dario Ordoñez. i need to replace a CU20025SCPB-T20A. and i want to Know if you could sale it me or tell me about someone that could do it.
    no mather if it is used. only the cheeper.
    if you can to help me whit this. i'll be thank you.
    please write me to darioordonez@hotmail.com
    best regards
