Build Advice How would this do?
Discussion in 'Hardware' started by gamergod05, 14 Jun 2009.
  1. gamergod05
    gamergod05 What's a Dremel?
    5 May 2009
  2. trig
    trig god's little mistake
    10 Aug 2006
    looks good. psu is a little overkill lol...but fine.
  3. gamergod05
    5 May 2009
    I got it knowing psu is over kill :p since dx11 is just around corner and it just going end up need more and bigger psu
  4. bagman
    bagman Minimodder
    18 Apr 2009
  5. gamergod05
    5 May 2009
  6. trig
    10 Aug 2006
    for the price they arent bad. i have them as well...
  7. docodine
    docodine killed a guy once
    10 Feb 2007
    This is your fourth thread about your new PC, go ahead and buy one! :D
    I'm not sure that just because new graphics cards will support DX11 they will have higher power requirements, that would be a step backwards in design. The first generation of DX11 cards might be a bit more power hungry than current ones, but probably not by much..
  8. ShwetaPrakash
    ShwetaPrakash Banned
    13 Mar 2009
    Alright im finished getting information
    http://www.*******.info/imgs/signature_deepthakur.jpg
  9. gamergod05
    5 May 2009
    Ya i wish i could im saving around 4,000 in summer to buy rig so won't be for 2 months
  10. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    a lot can change in two months.
  11. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    So should he never buy anything, since a lot can change in two months?
    Should I not buy food, since prices will fall in 2 months? :eyebrow:
  12. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Food prices won't fall, do you know. A piece of bread will be the same price after many months. Which is not true for computer hardware, obviously.
    And we didn't say "don't ever buy anything", we just told him to wait until he can buy. It's not a good idea to spec a super performance computer and buy it after a coupla months just to notice that it's actually not a very good performing PC in comparison with current ones.
