PSU HOWTO clean dust from PSU?
Discussion in 'Hardware' started by Bitwacker, 15 May 2012.
  1. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Pfffft and I thought it would be a fiver from poundland ;)
    Seriously though, compressed air is your friend for cleaning power supplies. No reason to take a PSU apart unless you know exactly what you are doing
  2. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
  3. adamix
    adamix What's a Dremel?
    21 Sep 2011
    It will definitely help get rid of most of the dust from within the psu. Obviously, as access to a closed psu unit is restricted, some dust will remain - this will also be the case if you're to use compressed air. The latter's real advantage is speed, really, which comes at a price. Giotto's rocket can be found for a bit less than the prices quoted above, and will probably last a lifetime (why not alongside a can of compressed air?). I agree with previous posts and would also advise against opening the psu - removing the last 5 micrograms of dust won't make that big a change.
  4. Williz
    Williz Minimodder
    9 Mar 2012
    That looks pretty useful, think I'll grab one of those as compressed air isn't that cheap!
  5. jaydeee
    jaydeee What's a Dremel?
    25 Apr 2010
    I use vacuum cleaner for this task. :)
  6. mecha.
    mecha. Newbie
    13 Jan 2010
  7. Bitwacker
    9 Nov 2009
    In the end a trusty vacuum cleaner did the trick. Which bring me onto the next question: what is the best way to stop dust building up again?
  8. Beasteh
    Beasteh What's a Dremel?
    18 Feb 2012
    Best thing to do is to fit filters to your case's intakes. Remember to clean out the filters once in a while! Other than that, PCs seem to get less dusty if you keep them off the floor (on the desk is good!) and keep the area around them clean, too.
