Notebooks HP G7000 Laptop not switching on, blue light on the power jack as normal
Discussion in 'Tech Support' started by maple, 1 Jun 2015.
  1. maple
    maple Minimodder
    23 Feb 2012
    As the title says the laptop won't switch on, the blue light comes near the jack and the charging light at the front, however when the power button is pressed it won't switch on.
    I've already tried taking battery out and holding the power button for around 30 seconds then trying it but no joy, i'm guessing it will need a new power board? what do you think?
  2. pilsner72
    pilsner72 Minimodder
    2 May 2011
    Could be a faulty power button or the ribbon from the switch or loose, not concrete just a suggestion. I have had 2 of these where they would not start up because the CPU fan was clogged up with dust.
  3. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Try re-seating the ram too
  4. maple
    maple Minimodder
    23 Feb 2012
    thanks, reseating the ram ive tried but hasn't worked, wouldn't a power button replacement solve the button, or ribbon problem
  5. Pookie
    4 May 2010
    It could also be a dodgy AC adapter, might be worth trying a different one before stripping the machine down.
  6. maple
    maple Minimodder
    23 Feb 2012
  7. Pookie
    4 May 2010
    It should have a HP spares number label on it, for example "367982-001".
  8. maple
    maple Minimodder
    23 Feb 2012
    ok thanks, is there one on the laptop aswell or do i need to strip and get to the power board and find the number on the power board then order one of the same number
    edit im looking at the back of it now and under the s/n there is p/n so i assume thats the part number
  9. maple
    maple Minimodder
    23 Feb 2012
  10. zenobia
    zenobia What's a Dremel?
    10 Oct 2014
    HP have live support that can chat them. You can ask them for solution on your hp laptop problem.
  11. pilsner72
    2 May 2011
    Should be ok for testing low voltage sources at that price not bad. Also it as a continuity checker so switches can be tested. Although if the led light is showing the adaptor is probably ok.
  12. pilsner72
    2 May 2011
    Yep the hp forums.
    If no look with the switch/power pcb, I have an intel T2310 it is 1.46ghz dual core free sent by slow post for test.
  13. maple
    maple Minimodder
    23 Feb 2012
    thanks for the replies, I haven't got round to replacing the power board just yet though i will be soon hopefully
