Cases HP laptop cases are terrible!
Discussion in 'Hardware' started by -equilerex-, 3 Sep 2009.
  1. -equilerex-
    -equilerex- What's a Dremel?
    3 Nov 2006
    Sooo... the other day my hard drive got fried. tried to boot up and it wouldnt... bios said the hdd's were bad
    after some messing with linux, it suddenly "resumes windows" :/ half the data is corrupt... luckily scan disc
    saved most of it.
    My conclusion after fiddling with the drives was that the heat killed them... so hot you cant even hold a finger on them.
    since the frackers were still running somehow (very slow with hangups every now and then) i plan the new drive purchase when i
    get to Estonia... for now, im thinking i could just do a "quick" cleanup for the fan... or so i thought
    23:42 one wrecked casing... really really poor design on these things... it has cracks all over the place
    no way to get close outside
    so it begins
    still no way to get close and the ******* is rather hard to take apart
    suprise suprise… the fan was the very last component to come out of the case /duh
    look at those dust bunnies
    unlike regular bunnies, these were as thick as the stuff under chair legs to keep the floor intact… and all openings were covered with them
    00:40 The “little” cleanup that should have been done ages ago took me an hour… who the hell designed a crappy case like this… all you needed was to attach the “mesh” under the fan with screws… the fan would be clean in 5 minutes. Next time it needs cleanup, il open it with a vertical grinder!!!
    The funny thing is that my gf has been pissed at me for a year since my pc sounds like a jet plane taking off…
    after this cleanup its tottally quiet and even runs way cooler then usual.
  2. GoodBytes
    20 Jan 2007
    Next time, look at the Latitude E series.
    1x screw (attached) bottom panel. Unscrew it, and slide the panel downwards (like remote battery cover), and you have FULL access to the system. This means, you can change the CPU, motherboard, wireless card, bluetooth, these internet on the go card, heatsink, fan, CMOS battery and RAM. The only thing you can't remove is the GPU but that is soldered in to the motherboard (as expected).
    Laptop base, panel, speaker grid and screen lid is in metal, the rest (screen frame, palm rest. keyboard, mouse, etc... is in plastic). This means, it's not going to be like the Lenovo where you toss around and won't show a scratch, but it won't scratch because you used a soft cloth (that is why I HATE glossy plastic, anything will scratch them)
    This is probably the easiest laptop to access every produced, and that will be produced.
    In case you don't believe me (full service manual): http://support.dell.com/support/edocs/systems/late6400/en/sm/html/index.htm
  3. mrbungle
    20 Sep 2004
    Heh i did a job for a customer on that same pos chassis around a month ago.
    Same problem. But **** it I like em to keep it that way then people dont get tempted to do it themselves :D
  4. Andersen
    Andersen Brain for hire
    25 Nov 2002
    Right next to the DVD drive, did the case melt or WTF happened to it?
  5. -equilerex-
    3 Nov 2006
    hehe, luckily enough thats just a bit of water from the table... cleaned it before starting to work.
    also, a little tip for hp owners... dont crab the laptop with one hand when taking it out of the bag/moving it/carrying it... ive got a nice dark spot now right in the middle of the screen
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    They are crap laptops build wise, friend has one after a while it kills HDD's. The HDD heat is trapped inside its caddy and just gets hotter and hotter!
    My 4 year old Acer Aspire, two screws, pop panel off, ooooooooo fan super clean! lol! Depending on usage i clean it once every month if its been on every day.
  7. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    those are the crappiest laptops ever made. at work this summer we had a pile of dead laptops that customers had left in our store, and all of the ones new enough to have PCI-e wireless cards were HP. also, if i ended up having to replace parts in a laptop to get it working again, there was probably a 60% chance that it was one of those. they just have totally ineffective cooling. i don't understand how they got out of the design phase.
  8. kenco_uk
    28 Nov 2003
    Did you have any screws left?
  9. Andersen
    25 Nov 2002
    QFT.
    I had three Pavilion series laptops. Each developed problems within first three monts, one was DOA right after I bought it. Replacement seppuku'ed itself but worked fine after a visit to the repair center.
  10. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    made me think i might give the eee a clean out. i have the same model as you have you tried cleaning it yet? easy?
  11. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Can you confirm that the audio / IR module at the front of the laptop is connected by one cable?
    I've just recently bought a second hand HP DV2630EA and the remote doesn't work. I've faffed around with drivers and I've confirmed that the remote is sending a signal (using my digital camera I can see the IR), so its most likely an IR sensor hardware problem. Its really annoying, but I don't really want to disassemble the laptop for such a small problem.
    Cheers. :)
  12. -equilerex-
    3 Nov 2006
    i actually had 3 missing :D
    @ oasked
    thats a really solid connection, dont see how it could be malfunctioning... actually, when the audio works then it cant be "badly connected" and a ripped wire aint big of a chanse either.
    im pretty sure its a driver problem... ive ran xp / wista /win 7 on it and i kind of remember having hell of a problem getting it to work on one of those... now on win 7 only the audio keys on the remote are working... with the drivers and software installed
    planning to build some extra cooling for the ****er soon.
  13. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Everyone talking about these laptops as crap, there's actually a genuine reason.
    I work in a computer repair shop, and these models (dv2000, dv6000, dv9000, and some Compaq models) have dodgy GPUs I think, or the graphics card part of the trip goes belly-up without warning, partly to do with overheating (they released a BIOS update that just speeds the fan up).
    We have a pile of these laptops dead in our shop.
    However, they did offer a free 'warranty service enhancement', giving you an extra year on top of the free warranty (1 --> 2 yrs total).
    See here for more info, and I just hope if any of you have one that's dead, that it's less than two years old :eek:
  14. oasked
    24 Aug 2005
    Yeah, its the nVidia 8400GS / 8600GT chip that's rubbish. It performs well enough but it has terrible manufacturing issues (like the Xbox 360). After too much heat stress it just breaks.
    Thanks for the pics and explanation equilerex! :)
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    +1 for the dodgy G84/G86 GPUs, we've warrantied most of the ones we sold. The ones we haven't, didn't buy the warranty.
  16. Andersen
    25 Nov 2002
    Talking to me?
    No idea. I havent taken mine apart (yet) except doing the very simple HDD cooling mod. But I'd imagine that it would be easy with normal precautions. You should get very far by checking out Eeeuser.com forums.
  17. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    i've had nothing but horrible hp consumer laptops. they're not durable, they feel like crap when you're using them, they run hot, and they're pretty much dead after a year (which is also when the warranty expires)
    however, if you think that case is bad, have a look at the older ibooks. want to take out the hdd? gotta take out the logic board first.
  18. KayinBlack
    2 Jul 2004
    That's after you pop the glue.
  19. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    This is why you don't buy consumer products. As soon as you upgrade to business models everything gets much easier. (And you don't have to deal with those damn glossy screens!)
  20. docodine
    docodine killed a guy once
    10 Feb 2007
    We owned two HP laptops, the less hot one pretty much melts anything plastic left within a few inches of the single vent, and the hotter one just shuts itself off after an hour of use. I posted a thread about how tough the hotter one was (it survived a fall off my SUV at 25mph), but it really is a POS..
    Will only buy Dell or Acer from now on, Toshiba isn't bad either.
