News HP laptop gets 24 hour battery
Discussion in 'Article Discussion' started by CardJoe, 11 Sep 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I could do with another hour out of my laptop, currently getting 2-3 with standard settings, medium back light. There was no way I was going to shell out $250 for an extra 3 cells in my battery.
    I wonder when the battery tech will be available for other manufacturers.
  3. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    plug one of these into your gaming laptop and run it for an astounding 30 minutes longer than standard batteries!
  4. Firehed
    15 Feb 2004
    I'd be more than thrilled to get a solid work day's usage out of a laptop (10-12 hrs for me), but HP could make a laptop that had a battery lasting a month and I still wouldn't touch it with a ten foot pole. Their laptops suck. They're just awful. Quite possibly the worst trackpads ever conceived by mankind, never mind the usual crapware preinstalled on them.
    But it hardly matters. If I've got my brightness down all the way (I usually do anyways, out of habit), I might be able to get 2.5hrs or so from my current maxed-out MBP. It only gets used in bed now for the most part though, since getting the MacPro. I'd consider one of the ultraportables (netbooks? is what they're called these days I guess...) but (free) wireless isn't nearly ubiquitous enough for one to make sense outside of the house, and I'd much rather sit down to my desktop when at home. For what I do, a full-size notebook doesn't make a bit of sense - it's either too small (coding) or unnecessarily large (browsing, email, etc). I think the ~1024x600 on the 10" mini units is passable, but quite honestly I'd go mad not having textmate even though I hate coding from a laptop and the only osx86 hacks for the mini units breaks wifi without replacing the card, which completely defeats the purpose of having one of those systems in the first place. Blah, I've fallen victim to good software.
    What I really wish is that manufacturers would stop putting useless crap for the battery information. Yes, I obviously can translate the unpublished power consumption specs into estimated hours of runtime from "32WHr 4-cell"... (unrelated: how on earth does a dell mini-thing come out $15 cheaper with XP home than ubuntu with the same hardware?). If they're going to publish overinflated numbers they pulled out of thin air, fine, but at least they're vaguely useful.
  5. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    I read somewhere (possibly el reg), that the indication is subject to a couple of things... effectively (accordin to the article in question), some very specific drivers (assumption is that these have naziesque power saving features built in), specific display, etc... and a secondary battery...
    more about that on theReg hardware
  6. paulwebber
    paulwebber What's a Dremel?
    15 Sep 2008
    erm...just making a small point, would 24hours on a laptop be quite bad for your health? just a thought...surely you would want it to last when u need it to but u dont need 24 hours!! maybe 8? just to last the day and then charged up at night. it really annoys me with this sort of advertising too because its always 'up to 24 hours' thats if you basically turn it on and not use anything on it!! as soon as you use something on it the battery life dives!!
  7. clairefu
    clairefu What's a Dremel?
    25 May 2012
    My friend's HP's have always gotten way better battery life then what I get. Granted their 484170-001 battery is usually a little thicken then the machine, but some people would rather have that much life. I fully agree with you iJon. You would think that hp 484170-001 battery technology would be a little more advance than it currently is for both laptops and cars
Tags: Add Tags
