HPR-4 Flame'D
Discussion in 'Project Logs' started by Defyant Mods, 12 Feb 2006.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Cheers guys :)
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Defyant's work rules :rock:
    Love the clean execution on every mod you touch bro :dremel:
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Sorry, did miss this. Maybe I got a little bit too excited because you're back at it and I just didn't read carefully enough. :eyebrow: :D
  4. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    mmm, yep! :rock:
  5. gigik
    gigik What's a Dremel?
    18 Aug 2004
    nice flamez
    nice flames, i like the plexi side, sure take a lot time
    gl+hf
    ps: I have my custom flames paint only just on my dvd, kvm switch and cellpohne :)
  6. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    looks really nice. i like branded cases because some of the time they are made out of plastic which is alot easer to fix when you screw up
    -hobbs
  7. Defyant Mods
    14 Sep 2004
    I went off on a bit of a Tangent today! bit more self indulgence. I'd had an idea thru the week and having a spare front panel to play with i'd thought i'd give it shot!
    I wanted to spice up the old "blow hole" mod, give it somthing new :)
    The modded panel and the new one i'll use for the new defyant style blow hole :p
    I'll pretty much skip thu the cutting hole process, all been seen before.
    This blow hole is going to follow the shape of the case and be a raised type.
    The new part or extra to the blow hole will be it'd side vents!
    This is the first time ive tried this mod, it's ganna be messy soz, but bear with me and hopefully the end result will be worth the time. :)
    No rocket science just mark and cut :p
    The left over will be bent down to help with the shape of the vents.
    Some left over 100mm pvc from the blowhole is cut into 2 small strips.
    And pretty much "jammed" and araldite glued into the cut slots.
  8. Defyant Mods
    14 Sep 2004
    You all knew this next part was comming :)
    Again im skipping thru the several layers of bondo ive applied.
    Some final 2pack qick dry fine sand putty is used....more or less fancy blade putty as ive used earlier.
  9. Defyant Mods
    14 Sep 2004
    As you can see i'm trying to work 2 contrasting shapes against each other in the hopes that they will become more interesting to look at.
    With the one side almost complete ive poped the front facia on for a good old "looksee" :)
    I'll update tomorrow with the other vent completed and the whole panel under putty.
  10. jrs77
    jrs77 Modder
    17 Feb 2006
    I wonder all the time, where you get all these HP-Cases. They are really good to work at. Do you have a little hint for me, where to buy one?
    BTW: Rock on...
  11. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    w00t, good to see you back here Def. Awesome modding as ever! How are the cinema displays doing? :D
  12. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Simply fabulous work...great!
    Go go go! :D
    hellas91
  13. perplekks45
    9 May 2004
    You know what I do like most about you and your projects?
    You never stop surprising me. :)
    Great idea with the front vent... and hell yea that's messy. :eyebrow: Show me something not looking perfect about this.
  14. Defyant Mods
    14 Sep 2004
    a bit more work today :)
    altho still no where near finished i can get a good look as to how the new front will now look.
    The 2 vents are not as perfect as would like and one is slightly more open then the other, this i can fix.
    now that thyr under spray putty i can get the lines right and finish them for the next update.
    The "finishing" putty i'm using id a pro type qick dry 2pak stuff, i'm using this because it drys and is sandable within minutes!it's expensive but gets the job done for me a lot faster.
    This stuff is mixed in small amounts and used as needed to fill the pits etc.
    The vents are worked some more and put inder a few coats of spray putty.
  15. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Nice bondo work on the front that air intake looks real bad ass ;)
  16. Zds
    Zds What's a Dremel?
    3 Nov 2005
    Wow, the new front panel really kicks ass! The old one was nice and well implemented, but this new one is a real eye-catcher.
  17. perplekks45
    9 May 2004
    Imperfection huh? WHERE?! :eyebrow: ;)
  18. Defyant Mods
    14 Sep 2004
    While this mod is not going to be a HP3-MRGA when it comes to lighting effects ,i still wanted to add something new.
    What i decided upon was a very simple yet modular design that would allow me (with the use of LED lit fans) to swap lighting around to suit the case. A blue fan id used for now but a RED, GREEN ,UV etc can easily be added to the carridge.
    I wanted to add lighting that would add to the blowhole/turbine effect, but not distract too much from air flow.
    A qik trip to the local plex shop and i was home with the parts needed :)
    The major part of this next mod are the 2x 50mm long Perspex tubes , the outer is 100mm and the inner being 80mm.
    The modular part of the mod is an old fan holder from a HP server. I will be altering slightily to suit this mod.
    Shown here is the cutting away ow the middle area to allow the nosecone to come thru,
    In the end i removed all the round grill bits and just left the 4 support posts.
    The next shot pretty much gives you the idea of what im after!
    The plex tubes are taken inside for a qick sanding
    Dried and cleaned
    To help the new paint stick the "inners" of the plex tubes are coated with plastic plex prime.
    The the "insides only" are painted with Platinum silver.
  19. Defyant Mods
    14 Sep 2004
    Once the paint has dried the ends of each tube are given a qick sand to remove the overspray.
    Then these are glued to the also previously painted and dried fan ex holder.
    For testing i'm going to use a spare CM BLUE 120, this type of fan is totally perfect for this mod! the 4 placed LED's that are already on the fan will carry along the tubes perfecty.
    Rubber gromets are used to support the fan, the fan is then bolted to the assembly.
    The assembly now works as one unit and can be installed and removed as needed.
  20. Defyant Mods
    14 Sep 2004
    Next is to test the lighting to ensure the light will actually travel along the tubes to the outer rim.
    It does! and as can be seen buy holding the light unit different angles can produce different effects :)
    Next to "SLOT" the unit over the blow hole.... the unit is a nice tight fit! and i doubt that it would easily slip off...but a permanent bracket will be attatched later.
    Lighting will also be added to the side vents soon!
