HPR-4 Flame'D
Discussion in 'Project Logs' started by Defyant Mods, 12 Feb 2006.
  1. Zds
    Zds What's a Dremel?
    3 Nov 2005
    This is *so* cool. Me likes.
  2. evilchickenman
    evilchickenman What's a Dremel?
    19 Dec 2005
    him and his plexi glass. i like blue koolant better than the green.
  3. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    wow awsome
  4. customh
    customh conflagration.
    22 Oct 2005
    Not that its bad but did you only do a mod on this particular case because it was what you had lying around or because you like it? It looks sweet, absolutely too many things to mention, the res looks sweet and your attention to detail in the painting process is immaculate, you should work in a body shop!! Keep it up!!
  5. FredsFriend
    FredsFriend What's a Dremel?
    20 Jul 2005
    Keep the vents black mate it's a nice contrast on the side. Or if you must paint them do them a similar blue to the plexi or NOS bottle
  6. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    More chop & shine!
    Every one of these flames have to be hand chopped and hand buffed! it was @ about this stage i was thinking that maybe i should have stuck with a 2pak paint job!
    The Vent panel was done using a block! this will sand qiker and flatter.
    It was @ this stage i was thinking "2pak" aint all that! :p
    With the chop and shine session now over! i can start hanging these panels on the case :)
    First panel to go on will of course be the base! SS hex heads replace the orig crap plastick bolts.
    With the base one next is to wire and bolt in the front fan assembly
  7. Defyant Mods
    14 Sep 2004
    Mesh grills are added to the side vents
    and the front panel is test fitted.
    Next on the agenda is to fit the Matix orbital LCD HDD and cdrom
    Now that the rest of the hardware is installed the front panel can be heated shaped cut and fitted.
    A simple solution for the CDROM is the same as used on HP1
  8. Defyant Mods
    14 Sep 2004
    Something i wanted to do to the last HP's but couldn't due to the external RADS was install the "backpanel"
    This is such a cool looking addition to the over all complete look of the case.
    Just for the sake of being "quirky" i glued back on the original sticker :)
    The rest of the wires are covered and connected.
    The light wire for the NOS res is now routed from the back of the case
    the marks for the Side vents are added and the vents are stuck into place
    For the SIDE flame window i brought 2 peices of plex! Dark and light tint.
    for now i will go with the lighter of the 2 windows
  9. Defyant Mods
    14 Sep 2004
    All thats left is to hang the white sheet and shoot up some fancy money shots :)
    The case unpowered....
    With some power added :)
    CDROM
    Base Flames
  10. Defyant Mods
    14 Sep 2004
    Side Vents
    Night shots
    Window Flames
    final'e
    Still got a few things to do! the front fan does not have active lighting , this will be swapped over thru the week. I'd also like to possible @ some stage add some of the blue plex fames to the outside ofthe case. :thumb:
  11. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    WOW sweet
  12. Drackhon
    Drackhon What's a Dremel?
    13 Mar 2005
    O yeah man, that´s incredible, It´s perfect, like the MOD i´ve have dreamt. It´s super, the NOS bottle.... :jawdrop: !! How can you do all you do in all your MODs?
    I have a cuestion, what do you do with all the MODs you build? During this last 6 months you have done like 5 cases....
    I LoVe YoU :naughty: :thumb: !! Don´t think badly... :nono: :clap:
    I´m still finding a case like yours... I´ve looked everywhere but it´s iposible to find a case like you have.... :waah: !! Could you help me?
    Drackhon!!!! :dremel:
  13. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    You and your sickeningly slick mods... :D
  14. Rd52
    Rd52 Minimodder
    3 Jun 2005
    Damn that came out nice :), same question as above what do u do with all your mods?
  15. en4cer
    en4cer What's a Dremel?
    5 Mar 2006
    Very nice work, you have great taste. :thumb:
  16. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    I think I just found my religion...
  17. jrs77
    jrs77 Modder
    17 Feb 2006
    Reallz nice ;)
    But I found one mistake. You glued this HP-pattern wrong sided to the bracket on the backside. But theres really nothing else to mention :sweet:
  18. WTF_Shelley
    WTF_Shelley The picture is wheeljack
    6 Apr 2005
    Damn i buy that case, hell i'ld have its children
  19. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Wow, that is Bit-Tech'd :D
    Totally awesome :thumb:
  20. Gumbatron
    Gumbatron What's a Dremel?
    18 Nov 2004
    WOW :jawdrop:
    They just keep getting better and better. Is there no end.....
    Has anyone else noticed that the Sticker on the Back panel is on upside down? You are human after all... :D
