HPRES III MEGA Complete, ty all.
Discussion in 'Project Logs' started by Defyant Mods, 3 May 2005.
  1. OtakuHawk
    OtakuHawk New Member
    30 Apr 2003
    This man needs the custom title of "Acrylic Master"
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Not only 'Acrylic'... I mean: Show me something this guy can't do. :D
  3. mondriaan
    mondriaan New Member
    20 Aug 2004
    You are amazing. :thumb:
    It keeps getting better and better
  4. giorgioprimo
    giorgioprimo New Member
    19 Jul 2005
  5. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    As I've said on WizD.... Very nice work, even though the mobo cover doesn't trip my trigger. You've still got a lot of talent that you used to good advantage.
  6. barbz
    barbz New Member
    31 Jan 2004
    hey dude, its excellent work, Ive been watching your work and it is very nice :D. Anyway, your in Sydney right? i was just wondering where you were sourcing your plexi from, I wanna get some to get into it, thanks a lot.
    -BaRbZ
  7. Pitbull
    Pitbull New Member
    20 Mar 2005
    Pfff ,, nice man!! :jawdrop: :jawdrop: :jawdrop: :jawdrop:
  8. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    thnx guys :)
    barbz i get all my plex here :)
    www.plastix.com.au
    i really needed to get on with finsihing off the rest of the lighting for HPR3...as will all the lighting so far its been double the effort...for every blue LED i install i have to install a red one as well... all up so far a whopping 20 RED and Blue LED's go to make HPR3's internal lighting.
    Power is added to the front CDrom and HDD cage.
    a molex is depinned, a hole cut and fitted back into the unit..this will supply power for the front of the case.
    The original idea was to add some old intel slot type heatsinks to the side of the HDD to help cool.... i scrapped this idea and went with a cutom drilled
    plex bracket mod instead.
    2 peices of polished cut to size 10mmthick strips of plex are drilled.
    Then re-drilled to add a stepped type counter sunk channel to both the brackets.
    This allows the HDD screws to fit all the way down the tunnels.
    These will act as "risers" and lift the HDD above the clear 80mm fan that will be mounted in the bottem of the box.
  9. Defyant Mods
    14 Sep 2004
    Holes are drilled and counter sunk for the 80mm exhaust fan. Again steinless steel HEX head bolts are used.
    The set of RED/BLUE Leds are installed and wiring completed for power.
    The 4 LEDs installed are to supply Light to the Lower Fan box, Small holes are drilled and the LDS poke thru the base of the HDD box shining down onto the Fan Box.
    Looking UP @ the unit you can see how the lights will shine down.
    This shot shows both blue and red LEDs running @ once.
    Just blue LED's
    The end result..showing all three colour effects.
  10. perplekks45
    9 May 2004
    Excuse meee? You a bitch!
    Damn sexy!
    /me is impressed as usual. :)
  11. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    umm... what? :eyebrow:
  12. Defyant Mods
    14 Sep 2004
    hehe it's all good aon :) cheers mate .
    PSU Sleeving
    the original plan was not to cover the wires from the psu at all, the idea was to paint them a very light dusty silver..playing with the frosting technique i discovered that this could also be applied to "clear rubber hose"!
    The only problem was i didn't have an atx depining tool!...i should! but i don't :)
    an easy way around this was to splice the clear hose and then recover it using Clear heat shrink! which i had plenty of :)
    A side bonus is that this way adds another cover that also adds to hide the wires and add to the fronst effect.
    just like with the frosted plex tubes!
    watch fingys :)
    slip some clear heatshreink over then slide the tube under and add heat.
    with a bit of reheating you can get a very good degree of "bendability" :)
    do the same with the other tubes to match.
    some final shots! almost "marketable" :)
  13. GuardianStorm
    GuardianStorm Active Member
    26 Apr 2005
    Noice work mate, what are the 'blocks' you are using that have LEDs in (look towards the begining of the thread)?
    I have started using clear RJ45 connectors to hold leds, if you remove the contact pins from it then it looks Uber :). I love the frosted plate on the back, gives a brill ilumincance, excellent insparation for my mod :naughty:
  14. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    WoW!
    Very very nice work :)
  15. MoOstick
    MoOstick New Member
    28 Jul 2005
    Frankly that PSU is gaaaaaw... :brrr:
  16. perplekks45
    9 May 2004
    Cheers.
    What you want for a PSU like that? I mean... this is great!
    I have this one and it's nice... but it's kinda noisy when pushed to the limit.
    However I manage to do so with an Athlon 2600+ and a GeForce 6600GT. :eyebrow:
  17. barbz
    barbz New Member
    31 Jan 2004
    just an idea dude, did you concider cable sleeving the powersupply cables before u shrink wrapped them, just an idea, like, dont u wanna reduce the sight of little cables?
  18. perplekks45
    9 May 2004
    You mean like sleeve the cables, put it in the tubes, then heat shrink them?
    Hm, I don't know if it was worth it. But in fact it would give you the possibility of totally hide those 'too' colorful wires.
    Maybe someone should do something like this to let us see how it would look. :D
  19. frodo
    frodo New Member
    1 Nov 2003
    i agree with the two above posts, it would look really sexy if the cables were sleeved and THEN tubed :D bit like the expensive ultra psu's
  20. ginx
    ginx New Member
    1 Sep 2004
    havnt been on this forum in quite a while, and ive missed a lot here since you first started. and all i can say is holy crap this is effing sweet man. i love it
