HPRES III MEGA Complete, ty all.
Discussion in 'Project Logs' started by Defyant Mods, 3 May 2005.
  1. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Let me steal this line from Nexxo... TOO JUICY!
  2. Defyant Mods
    Defyant Mods Well-Known Member
    14 Sep 2004
    cheers sbe :)
    The first attempt i had @ this solution was bulky and awkward looking.
    AS you can see below...the bulky black leads just did not work!!!
    In an attempt to streemline and make the detachable dual lights more eye pleasing i came up with this.
    the method of making the Dual lights was the same as before but this time ive shortened the shank of the silde on light to help streamline,
    also added "white" wires to help keep a cleaner more "intheme" look.
    The cover with the slot type groove that slides over the edge of the motherboard cover.
    The legs are bent closer to the LED this time.
    White wire which is then covered in Clear heatshrink is soldered on
    The step down resistor is then soldered to the end...this takes the "bulk" out of the loom.
    A qick check of the plex cover shows that it can be shortened soome more!
    after some more filing and a qik "frosting" the cover is ready and slipped over the LED's...a dob of HOT glue us used to hlod it in place.
    Some Clear heatshrink is slipped over and shrunk down to complete the look and the whole loom is also covered with clear heatshrink.
    I'm much happier with this look :)
  3. J-Pepper
    J-Pepper Active Member
    20 Jul 2004
    WOW! :jawdrop:
    This is what I call a real case mod! Put's my attempt to shame!
    Carry on with the work and mod on..! :dremel:
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Maybe you should reconsider renaming to DÈFrost¥âÑt¸.·´¯`¤. :D
    You really take care of every detail. What else can I do than bow down to you?
  5. X_VADER_X
    X_VADER_X New Member
    7 Sep 2005
    I really like clear transparent cases... and when you throw i alot of neon lights it looks like a rainbow!!! :D This is a nice case...
  6. Lord Kordir
    Lord Kordir New Member
    5 Nov 2003
    God, I'm subscribed. I couldn't even begin to do a mod like this. Yet another thumbs up! :thumb:
  7. huren
    huren New Member
    14 Aug 2004
    nw.
    the white / clear look is pure class and suits the downpat.
    looking forward to more =D
  8. pc-modd.dk
    pc-modd.dk New Member
    22 Apr 2005
    Nice psu sleeving -- good idea.. :)
  9. D B
    D B New Member
    11 Apr 2004
    Happy Birthday Defyant !!!
    He, He, He, :thumb:
  10. ginx
    ginx New Member
    1 Sep 2004
    Hey DÈF¥âÑt¸.·´¯`¤, I saw some of your work in a magazine today while browsing through the grocery store. I was like "hey, I reconize those!". Anyway, as usual, coming along great man, can't wait to see this one done yet, I think this is going to be the best one so far. :D
  11. Chrome
    Chrome New Member
    26 Sep 2005
    inspired, registered, subscribed.
  12. Defyant Mods
    14 Sep 2004
    Thanx guys :)
    Cheers DB for the HB mate :)
    Thanx ginx! its a always a good feeling to see your mods in a mag :) somthing i'll never grow tired of :)
    Really hoping to get STORM'D finished in the next few weeks and get back into HP3.
    I never planned after PeRs-pLeXeD to spend this much time on a another small mod.... but STORM'D is turning out to be **** loads of fun :)
  13. Defyant Mods
    14 Sep 2004
    This is the continuation of the front panel idea. i had originaly made 3 light fins the top one will act as the door for the cdrom.
    These were all made from 10mm thick plex cut then hand shaped.
    The problem was, the top one bearly covered the cdrom hole.
    Was time to craft a bigger unit !!!
    This is a massive chunck of plex! @ near 20mm x 20mm this was not easy to bend into shape 5 mins of solid hot air gun had it like rubber.
    It was then lay'd over the from of HP3's front and left to cool down and go hard again.
    Clamping the plex to the bench and using the dremal to knock the corners off.
    40 minutes of hand sanding and the new door is taking shape.
    a quik test to see that it covers the cdrom opening
    and its back for some more hand sanding
    after another 20 minutes the peice is almost at the right shape.
    some work is done to the matching middle strip
    and the 3 peices wrk from large to small ...the larger veing the cdrom door the smaller 2 being for balance and athestics.
  14. Defyant Mods
    14 Sep 2004
    the thicker top plex contour will have to attach to the cdcrom door , for this a custom extension block is needed.
    the block will act as the spacer between the new cdrom door and the cdrom tray itself.
    The block is shaped to suit the conture of the new plex door
    and a qick mock up is done to see all is goin to plan.
    As seen above the new cdrom door has now been sanded with finer gritt paper and has a smooth frost look.
    The spacer block is to be left clear and not frosted, holes are added to help lighten the load and to add some asthectics.
    This new unit is not to be attached to the cdrom tray to become one.
    Holes are drilled in the tray
    matching holes are also drilled into the connecting block
    Threaded using a 5/32 fine tap
    the whole unit is then bolted together using hex head SS bolts.
  15. Defyant Mods
    14 Sep 2004
    With the cdrom in this now add as the joiner between the tray and the new plex door.
    The front door will be eventually attached after painting of the case and a special "silicon strip of double sided clear plex tape " will be used to hold it in place.
    The end look will be the 3 plex contours sitting spaced evenly and dual lit.
    it does feel good to be modding this case again! :)
  16. frodo
    frodo New Member
    1 Nov 2003
    finally an update!
    it looks very promising, having the cd drive stealthed like that really does kickass! :p awesome work as always
  17. perplekks45
    9 May 2004
    Agreed with above. Just what I thought. You let us wait a long time mate... but you did kinda nice things in this time. :D Btw: What about the 3rd of your 'weekend projects'? Did I miss it? Haven't had that much time the last 2 weeks... university, F.E.A.R. MP... ;)
    And you love those hex bolts, don't you? You seem to hex bolt everything.
  18. Defyant Mods
    14 Sep 2004
    Cheers frodo :)
    just wating for the new plex case to arrive :)
    yer!!! @ 70cents a pop! i won't be loving them for tooo much longer!
    Side Panel 1.
    Side Blades
    To keep "intheme with the rest of the mod, ive decided to balance the case up with some "side blades" Again! these are hand sanded from single strips of 8mm thick clear plex.
    The idea will be to add the blades to to fit in with the cut panel.
    As seen here, i really like that way the cut shapes fit in with the overall look of the case.
    The only prob is that the case looks "unbalanced" remember theres w whopping great 2 ltr tank sitting off the other side of the case... to leave this side "Flat" would make the case look unbalanced.
    Not wanting to turn this side of the case into just another "bondo" moulded panel, i thought to work a look that would fit in and give me the "balance" im looking for.
    Long winded sorry....but ive been thinking about this for 2 months now :)
    HP3 with the ex hp2 side panel
    The idea is pretty simple shape this peice of plex into a thinner blade.
    the peice is "sliced " in half length ways.
    after 20mins of initial sending the 4 blades are in ruff form.
    2 hours later the blades are in almost final form.
    The purple panel is sanded and re-spray putty'd and the Blades are layed on for a look.
    The blades will have no "active" lighting at all...the idea is the light from within the case will be caught on the blades top edges providing the light needed to to achive the end effect.
  19. Defyant Mods
    14 Sep 2004
    "The blades will have no "active" lighting at all...the idea is the light from within the case will be caught on the blades top edges providing the light needed to to achive the end effect".
    i gotta admit! i wasnt to sure about what i had stated there!
    so it was out for some qick testing!!!
    The side on shot! dosnt show any effect.... altho this is under light,
    but when you walk around the case!! the "Blades" come to life!!
    thought i'd wire up the cdrom to power for a test "eject"
    the lgiht source for the door is also passive!! no extra LED'S need to be added.
  20. Defyant Mods
    14 Sep 2004
    Some mandatory night shots!
    I't took a while to come with a solution that fitted in with the rest of the case..... the Blades are an easy yet effective solution to balancing the mod.
