HPRES III MEGA Complete, ty all.
Discussion in 'Project Logs' started by Defyant Mods, 3 May 2005.
  1. drftkng
    drftkng What's a Dremel?
    2 Jun 2005
    simply amazing :jawdrop:
    going on the previous two, this one should be just as incredible
    subscribes :thumb:
  2. Drackhon
    Drackhon What's a Dremel?
    13 Mar 2005
    WOW!!! What a remodelising work, very nice man.
    Drackhon!!!! :dremel:
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    love'd the previous one, and this looks good already! mod on :dremel:
  4. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Man you keep doing this i'm going to run out of pants to crap in!! Simply amazing!!!!
  5. phantomxc
    phantomxc What's a Dremel?
    7 Dec 2004
    that sums it up pretty good. you get the idea..... :p
  6. frodo
    frodo What's a Dremel?
    1 Nov 2003
    The way you have done that is simply amazing, i love your work, it raises the bar of modding and bondo work!
    i really want one of those cases now!
  7. Devil_909
    Devil_909 What's a Dremel?
    16 Mar 2005
    This is what modding is really about. Taking a boring beige case and making into something amazing. Good work so far. Wish you would hurry up and post some more updates :)
  8. jtaing858
    jtaing858 What's a Dremel?
    10 May 2004
    DAM....speechless..i have a case similar to that also..maybe ill do some moddin on it also
  9. m0gu
    m0gu What's a Dremel?
    7 Jun 2005
    :jawdrop:
    awesome work
  10. Draeth1
    Draeth1 What's a Dremel?
    5 Jan 2004
    I have a request of the bondo god, could you do a guide? Like a pic showing how much you mix of each and how you get so much bondo applied before it clumps up like wet clay :) I'm trying a little bondo work and I can't get much more than a silver dollar sized lump applied before it gets pasty.
    If there is already a really good guide out there (with pics) can someone point me towards it?
  11. jackjr
    jackjr What's a Dremel?
    27 May 2005
    that mesh is a pretty good idea.. I was trying to figure out where to get some and seeing this made me realize all the dead monitors I have around here - I've got piles of the stuff!! Your mod is really turning out spectacular!
  12. frodo
    1 Nov 2003
    hey jackjr, try mixing less hardener with it! i can get huge amounts out if i use small amounts of hardener (takes longer to harden - not hard to guess) so just use less and you'll be fine
  13. Draeth1
    5 Jan 2004
    hehe that was me that said my stuff turns to lumps quickly :)
    I tried putting less and it never hardened, maybe I didn't put enough that time. Thats why I asked for a pic, its easier to see ratios than have the can say 1/2 a tube to 1/2 a can.
  14. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Dreath1 the mixture varies depending on brand and type,
    i can't imagine it dosn't tell you on your can? or on the tube , mostly its around 50 to 1.... but you can up or down it 50% on that again to suit your needs....ive never herd of bondo going clumpy? i have a guide poster here.
    but its more about the mod rather then just bondo. have a look it may help.
    http://www.casemodgod.com/cmg/ftopict-4126.html
  15. Defyant Mods
    14 Sep 2004
    got a few hours tonight so i knocked over the fanbox,
    first off was to knock all the edges off using some 60g
    counter sink the holes, better to do this now before the bondo hits!
    cut some stips of flexable plastic, im using these as the guides an they will simply peel away @ the end.
  16. frodo
    1 Nov 2003
    Any updates?
    Are you going to spruce up the rad in the top? say chromed?
    this is going to look schweet!
    you posted @ the same time as me :( damn!
    that looks good!
  17. Defyant Mods
    14 Sep 2004
    Bondo time!!!!
    i want to add small blow hole lips to keep with the theme inside and out.
    First of 3 layers of bondo.
    starting to take shape
    after another bondo and rub.
    peel the plasitc guides away
    a qik rub on the iners
    redrill the screw holes
    finally some spray putty,
    so far so good :)
    will wet rub this in a few days-to a week, then another sprey with putty before paint.
  18. frodo
    1 Nov 2003
    :O amazing work defyant!!!
    p.s i added you to my msn contacts list, but am not sure if you accepted me (tff_frodo@hotmail.com)
    i love the cleanliness of your bondo work!
  19. Draeth1
    5 Jan 2004
    It never ends, everytime I read an update to your mods I become a slack-jawed yokel.
    I've only got one question this time, where'd you get spray putty? I've never seen that in any stores in town. It sounds like its sprayable bondo to get that smooth look, do I have the right idea?
    Nice walkthrough on that link, somehow I had never found that one. Judging from the pics I was putting waaay too much hardener in, it was a nice red color. *bonk*
    btw part 2 is down again.
  20. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Thanks for the URL, might come in pretty darn handy!
