Modding Hrmmm... Painting This Water Cooling rig...
Discussion in 'Modding' started by ArmyAnt, 15 Aug 2004.
  1. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    Anyone see this water cooler?
    http://store.yahoo.com/maxcooler/noname314.html
    There is a review here:
    http://www.atruereview.com/silentstream/index.php
    and here:
    http://www.techwarelabs.com/reviews/cooling/globalwin_silentstream/
    Do you think the green could be re painted red? Also, would it be possible to place a vga cooler on it and possibly a custom res? I have never liquid cooled before... Do you think it would cool better than my shuttles ICE heat pipe? Its a 64 bit 3400+, shuttles v2 case.
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Not sure about the rest, but its not worth the money, it sucks.
  3. MRKIKKOMAN5645
    MRKIKKOMAN5645 What's a Dremel?
    2 Aug 2004
    i agree u dont wanna cheap out on watercooling stuff cuz if it is not good quality.. spring a leak..computer becomes something u have fun running over with a truck... save the money and get good quality :D
  4. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    check this site they have very cheep parts if your not after performance.
    Here is a kit Click Here
    They actualy have aluminum blocks for 15bux and pumps for the same price and if you use a rad from a junk yard or a new 1 from autozone you can build your own kit for about 50bux.
    EDIT: just checked they have chipset blocks that sell for 17bux
  5. Go4t
    Go4t i
    13 Dec 2003
    thats the kit that Robster used on the rc ssr shuttle so you should really ask him about it
  6. Enak
    Enak Also known as Kane
    23 Jul 2002
    Keep away from this kit... it is a hock of ****!
  7. ArmyAnt
    6 May 2004
    thanks for the great responce!!
